Go to Post In Israel we've got the president supporting FIRST and speaking at events, so it's time for you guys to catch up =] - Tottanka [more]
Unread 18-04-2016, 00:40
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Re: pic: Stripped VexPro gear
Originally Posted by Mechvet View Post
We blew every tooth off of two of the VexPro 14tooth 3/8 hex gears.
Turns out aluminum gears just aren't quite rated to the level of impact we were subjecting them to.
those gears are made out of 7075 Aluminum which is as strong as many types of steel, thats one impressive feet lol
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
Unread 18-04-2016, 00:48
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
"Strong" is a rather non-precise word for material descriptions.
Steel and 7075 may have similar load capability and shear strength, but when it comes to a sudden impact (ie a 145lb robot at ~12fps slamming into a barrier), the more brittle aluminum gear doesn't stand a chance.
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
In comparison with 4140( normal steel gear material) it has a higher yield strength, but a lower ultimate tensile strength. It also has a much lower %elongation. The percentage elongation means that it can't bend and deform as much before it fails
http://www.wcproducts.net/how-to-gears/
Facebook
Unread 18-04-2016, 02:12
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
The material of the gear is not the end-all deciding factor in whether or not it's strong enough for the job. If you stick enough torque on it, you can break anything!
Each stage of gear reduction adds up fast. Whenever we need a gearbox that needs more than 3 stages of spur gear reduction, I start to get a little paranoid. We underdesigned the 3rd stage of our stacking mechanism last year and separated several gears from their teeth when operating it with the braking mechanism engaged.
Always make sure each stage can handle the maximum torque the motor can output, and add however much cushion you think you need. (Then test test test... break it at your shop so you don't have to break it at competition)
Unread 18-04-2016, 02:31
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Originally Posted by R.C. View Post
For the 14T I would personally only use the steel in anything that takes moderate to high load and the aluminum one for low load. Or just use the steel one all the time since the weight difference is minor.
We found out the hard way losing in the Hawaii regional this year.
Our 14T aluminum hex gear and another of our aluminum VEXPro gear lost teeth in one of our trans. Could not swap out the trans in time for the next semis match.
In the past we always used steel and could see noticeable wear after running our robot for a lot of practice and real matches.
I guess with the aluminum ones, they just break teeth. :/
Unread 18-04-2016, 07:46
pfreivald's Avatar
AKA: Patrick Freivald
This is exactly why we lost the quarterfinals at Tech Valley; we saw that the gear was starting to strip, but the repair/swap would take too long. We hoped to survive through the tournament and would have made the semifinals if we could have driven ten more feet--but alas, it gave up the ghost on the wrong side of the (open) Sally Port.
We switched to toughboxes with aggressively-lightened steel gears for FLR and had no drivetrain issues throughout.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 18-04-2016, 08:06
CJ_Elliott's Avatar
CJ_Elliott CJ_Elliott is offline
FRC #2502 (Talon Robotics)
CJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of light
It's ok. We too lost teeth in semis and couldn't run at 10k... after having already replaced the 14 tooth gears in both gearboxes during quals. I feel like this whole 14 tooth aluminum gears thing is an issue.
Unread 18-04-2016, 08:58
Chris is me's Avatar
AKA: Pinecone
Personally I wish that VexPro would make all of their pinion gears (say 14-24T) available in steel as well as aluminum. They are a higher quality gear than AndyMark in terms of tooth profile, manufacturing tolerances, and quality in general, but being stuck with aluminum pinions can be somewhat limiting when you don't have the ability to compensate for the loss in strength in other ways (ie doubling the face width, different DP of gear, etc).
Unread 18-04-2016, 10:09
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Can anyone confirm, via math, that the steel teeth would have been strong enough to prevent total tooth failure? At the time this happened, we had to move fast to fix it for our first event:
For our tilt motor we ran a BAG -> 100:1 VP -> 20T/40T reduction and kept stripping the teeth on the 20T. This was because of the cantilever on the VP - the shaft would flex just enough to cause a LOT of stress on the teeth, and they'd strip. By the time this happened VEX was out of 20T gears, so we swapped to belts. We also added a plate on the other side of the cantilever with bearings to support it.
We're running WCP gearboxes with an extra 18->36T sprocket reduction (non direct-drive) and they have been flawless this season with no signs of wear on the sprockets. So I don't know that aluminum vs steel is the issue.
GitHub
Unread 18-04-2016, 13:27
waialua359's Avatar
AKA: Glenn
Is that really what happened? Holy Moly. Sorry to hear that.....I had wondered what happened to you folks when the backup robot was used.
For our situation, we had hoped to come back in and decided not to bring in the backup bot.
Unread 18-04-2016, 13:35
AKA: Pinecone
Gears versus sprockets are apples and oranges comparisons - you can't draw conclusions about material choice for one by looking at the other. Sprocket load is shared by several teeth at once, while gear loads are borne by just a few teeth at a time. Chain also dampens some degree of shock load, to an extent.
Unread 18-04-2016, 14:22
JesseK's Avatar
FRC #1885 (ILITE)
Hmm, fair point.
GitHub
Unread 18-04-2016, 15:05
CJ_Elliott's Avatar
Yea... 10k was a bit of a cluster. We broke every system on our bot, but we digressed. 3 grenaded drivetrain gears at 1 competition... I think that might be a record.
Unread 18-04-2016, 17:58
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
We also learned this lesson the hard way on the WCP SS gearbox. Fortunately it first happened during our 6-hour unbag window prior to our first competition, so it didn't cost us any matches. It did cost us 2x 45 minute teardown sessions (1 during unbag, and 1 at the event) to upgrade both competition gearboxes - We were also fortunate to already have the 14T steel gears on-hand, spared for another mechanism.
We also helped get 4469 back up and running with steel gears at PNW DCMP after they stripped the same 14T aluminum gear in the Vex 2-stage SS gearbox.
R.C. - It would be great if these two gearboxes were configurable with steel 14T gears, or even came with them by default for the relevant gear ratios. Currently only aluminum is available when building a gearbox for purchase through Vex or WCP - steel replacements have to be purchased separately.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 18-04-2016, 18:13
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Jeff,
I totally agree with you, I thought we made this change over. I will check and get this implemented, also have a few other changes planned.
R.C.
MadTown Robotics Team 1323
