#16
Re: Usign a 2-1/2 bore, 24" stroke pneumatic cylinder.
My team is using a 2" cylinder with a 24" stroke to hang our robot, but we're having problems retracting and lifting.
We were using a single air tank at the first competition we went to. It was found that gently nudging the robot at the start of retraction seemed to get it going. We then added two more air tanks and checked the gauges immediately after we extended to see if that was the issue. The high gauge read about 50psi, if I remember correctly, the low was 50psi for a split second and then back to 60psi. We did not have the chance to test actually hanging with this set up. We took our robot to a practice field, but our controller was not working correctly. To test our pneumatics, we tried to manually trigger the solenoid. This did not produce the results we were hoping for; however, it is unclear if this was due to the manual triggering or a pneumatics issue. Our robot weighs 77lbs with battery (and I believe bumpers). My questions: 1. How much time does a pneumatic of this size take to refill? 2. Will the 2nd and 3rd air tanks mitigate the time in question 1? 3. Is there anything else that can be thought of in relation to pneumatics that might need troubleshooting? Thanks for any help, indieFan |
#17
If you use constant force springs in line with your cylinder, you can use a smaller diameter cylinder. There's a voucher for six free springs from Vulcan in the KOP.
#18
We use two 1 3/4" BIMBA cylinders, and hang by the rods. We haven't had any pneumatic problems yet
We have 5 air tanks also, and run it off of two solenoids and two regulators. The solenoids each lead to both cylinders, and are slaved together. We do this because the internal diameter of one solenoid it too small to facilitate rapid airflow |
#19
I wonder if it would be better to actually put a pressure regulator between the extension-end of the air cylinder and the air solenoid valve and just extend at say 5-psi? If you can still reach up very fast but not actually pressurize the extending side of the air system to a very high number, you'll save all of that stored pressure in your tanks for the lifting-retracting stage. We built a robot-lifting cylinder in our prototyping at the start of build--used a 2" dia--which should've been able to lift 176 lbs, but with a 120lb robot, battery, bumpers and the added friction of dragging the bumper up the wall, it didn't move very well at 60 psi and was very slow after the air in the storage tanks was used up. I hope you can make it work. good luck. Also note, I know these equations are easy, but if you need a quick-reference for how much force each bimba-sized cylinder makes at 60 psi for pushing and pulling, I've created this easy chart. https://docs.google.com/spreadsheets...it?usp=sharing Last edited by hrench : 04-18-2016 at 10:10 AM. |
#20
Some math (maybe some graphs with an eye toward that 150-lb requirement) should help you determine an optimal* amount of spring vs. bore. *optimal, of course, depending on which resources you're trying to preserve. As another idea, consider constant force springs that are already extended along the body of the cylinder, but don't lock in to the rod until it's fully extended--so you don't have to push against them at all, but they'll help you pull it back. Might require some cams, spring-pins, or whatnot. |
#21
Your stored air pressure is a max of 120 PSI. Most pressure switches are shutting off at around 115 indicated. Your working air pressure shouldn't ever be above 60 psi.
#22
That's by design; see rule R17 C. Unless I'm misunderstanding your post you need to take a good look at R90.
#23
What I mean is that the piston will begin moving immediately when the pressure on the pushing-side of it has exceeded the resistance-- friction loads, weight and if you have them, springs. The piston will continue to move at very low pressure staying just ahead of the friction and load until the time that the piston reaches then end of travel. Only then does any real pressure build up inside the cylinder on the 'up' side of the piston. So if you have a pressure regulator between the valve and the piston, you'll be able to limit the pressure on the 'up' side of the piston to conserve air. Lots of it actually. You'll still need all of the pressure you can muster to lift the robot, so you can't put the regulator before the valve or anyplace that would limit the 'down' pressure. So if you don't have springs to overcome, you'd be able to extend the lifting hook under very low pressure, like 5 psi (a 2.5" dia has 4.9 sq inches, at 5 psi is close to 25 lbs force) Yes, this is a very interesting idea too. Though I would rate it as 'difficult'. Of course there are teams that completely lifted the robot with springs that were already storing energy too (I saw 1619) So in this iteration, if you used an air cylinder, it would only need to get the hook up to the bar. Could be tiny. Last edited by hrench : 04-18-2016 at 04:34 PM. |
#24
Yeah, yeah, yeah. Fingers before brain and all that.
60 psi working, not 120. ![]() |
#25
In regards to r90, I'm not sure that a solenoid actually qualifies as a valve, because (As I understand it) a valve contains or limits pressure, whereas a solenoid simply directs it one direction or another, without limiting it in any way. Based on that, we are basically just connecting two pneumatic tubes together. I'll check on that with our mentors in our meeting tonight though- I am but a humble programmer, so it is very likely that I'm incorrect on that. |
#26
#27
A 'solenoid' is a controlled magnetic field. We use a solenoid to move a piece of iron magnetically that operates an air valve. I sometimes refer to them as 'solenoid air valves' just so the people that call them 'solenoids' will understand, but yes, they are definitely air valves. And if you have two plumbed together on your robot to operate two cylinders, I encourage you to separate them before your next inspection. |
#28
In 2010 when you had to kick a soccer ball we (1922) used 4 solenoids all plumbed to one cylinder and had one of the strongest kickers around, strong enough that Dean Kamen was examining it at GSR. The next year was the first year that was not allowed. We kinda think we caused this rule. |
#29
Alright, things were cleared up for me at our meeting: They each route to separate cylinders, completely my bad on that one.
