Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 18-04-2016, 15:38
foote stepped in
AKA: E. Foote
FRC #0868
[2016] CMP prop bets
Following the same format from 2013, 2014, 2015, post whether you think the statement will be true or false. Betting stops when matches start. Good luck!
http://www.chiefdelphi.com/forums/sh...d.php?t=136661
http://www.chiefdelphi.com/forums/sh...d.php?t=115914
http://www.chiefdelphi.com/forums/sh...d.php?t=128855
NEW for 2016 - inspired by Dr. Joe's graciously sponsored competitions, I'll be offering a $50 Amazon gift card to the winner.
(to help speed scoring, please use code or quote tags around the following, and put TRUE or FALSE before each numeral, e.g. FALSE 1. Carson's red alliance...).
1. Carson's red alliance in qualification will earn more points than its blue alliance.
2. Carson's draw bridge will be damaged more than 30% of the time it is used in qualifications
3. Carver's blue alliance in qualification will earn more points than its red alliance.
4. Carver's cheval de frise will be damaged more when it is used in qualifications than the portcullis.
5. Hopper's red alliance in finals will earn more points than its blue alliance.
6. Hopper's rough terrain will not be damaged in 2 or more qualification matches.
7. Tesla's blue alliance in finals will earn more points than its red alliance.
8. Tesla's moat will be used more in qualifications than the ramparts.
9. Archimedes' red alliance in qualification will earn more points than its blue alliance.
10. Archimedes' sally port will be damaged more than 55% of the time it is used in qualifications.
11. Galileo's blue alliance in qualification will earn more points than its red alliance.
12. Galileo's rock wall will not be damaged in 4 or more qualification matches.
13. Curie's red alliance in finals will earn more points than its blue alliance.
14. Curie's low bar will be damaged 100% in finals.
15. Newton's blue alliance in finals will earn more points than its red alliance.
16. Newton's moat will be used more in qualifications than the rough terrain.
Inter-division
17. Carson will have a higher challenge success percent in qualifications than Archimedes
18. Carson will have a lower total breaches success percent in finals than Archimedes
19. Carver will have a higher total breaches success percent in qualifications than Galileo
20. Carver will have a lower total scales success percent in finals than Galileo
21. Hopper will have a higher scales success percent in qualification than Curie
22. Hopper will have a lower capture success percent in finals than Curie
23. Tesla will have a higher capture success percent in qualifications than Newton
24. Tesla will have a lower challenge success percent in finals than Newton
Einstein
25. The red alliance will win Einstein
26. An alliance with a total team number summation of less than 1500 will be on Einstein
27. An alliance with a total team number summation of more than 7000 will be on Einstein
28. There will be a 3rd match in the finals on Einstein
29. There will be 4 teams scaling in a quarter finals match on Einstein
30. There will be a score above 250 points on Einstein
Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 18-04-2016, 15:45
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: [2016] CMP prop bets
TRUE 1. Carson's red alliance in qualification will earn more points than its blue alliance.
FALSE 2. Carson's draw bridge will be damaged more than 30% of the time it is used in qualifications
TRUE 3. Carver's blue alliance in qualification will earn more points than its red alliance.
TRUE 4. Carver's cheval de frise will be damaged more when it is used in qualifications than the portcullis.
TRUE 5. Hopper's red alliance in finals will earn more points than its blue alliance.
FALSE 6. Hopper's rough terrain will not be damaged in 2 or more qualification matches.
TRUE 7. Tesla's blue alliance in finals will earn more points than its red alliance.
TRUE 8. Tesla's moat will be used more in qualifications than the ramparts.
FALSE 9. Archimedes' red alliance in qualification will earn more points than its blue alliance.
FALSE 10. Archimedes' sally port will be damaged more than 55% of the time it is used in qualifications.
TRUE 11. Galileo's blue alliance in qualification will earn more points than its red alliance.
TRUE 12. Galileo's rock wall will not be damaged in 4 or more qualification matches.
FALSE 13. Curie's red alliance in finals will earn more points than its blue alliance.
TRUE 14. Curie's low bar will be damaged 100% in finals.
FALSE 15. Newton's blue alliance in finals will earn more points than its red alliance.
TRUE 16. Newton's moat will be used more in qualifications than the rough terrain.
Inter-division
FALSE 17. Carson will have a higher challenge success percent in qualifications than Archimedes
TRUE 18. Carson will have a lower total breaches success percent in finals than Archimedes
FALSE 19. Carver will have a higher total breaches success percent in qualifications than Galileo
FALSE 20. Carver will have a lower total scales success percent in finals than Galileo
FALSE 21. Hopper will have a higher scales success percent in qualification than Curie
TRUE 22. Hopper will have a lower capture success percent in finals than Curie
TRUE 23. Tesla will have a higher capture success percent in qualifications than Newton
FALSE 24. Tesla will have a lower challenge success percent in finals than Newton
Einstein
FALSE 25. The red alliance will win Einstein
FALSE 26. An alliance with a total team number summation of less than 1500 will be on Einstein
TRUE 27. An alliance with a total team number summation of more than 7000 will be on Einstein
TRUE 28. There will be a 3rd match in the finals on Einstein
TRUE 29. There will be 4 teams scaling in a quarter finals match on Einstein
FALSE 30. There will be a score above 250 points on Einstein
177 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
100% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 18-04-2016, 15:58
NicusTM's Avatar
NicusTM NicusTM is offline
AKA: Nic
FRC #3216 (Missoula Robotics Team)
Team Role: Student
NicusTM is an unknown quantity at this point
FALSE 1. Carson's red alliance in qualification will earn more points than its blue alliance.
FALSE 4. Carver's cheval de frise will be damaged more when it is used in qualifications than the portcullis.
FALSE 5. Hopper's red alliance in finals will earn more points than its blue alliance.
TRUE 9. Archimedes' red alliance in qualification will earn more points than its blue alliance.
FALSE 12. Galileo's rock wall will not be damaged in 4 or more qualification matches.
TRUE 13. Curie's red alliance in finals will earn more points than its blue alliance.
TRUE 15. Newton's blue alliance in finals will earn more points than its red alliance.
Inter-division
TRUE 17. Carson will have a higher challenge success percent in qualifications than Archimedes
TRUE 21. Hopper will have a higher scales success percent in qualification than Curie
FALSE 23. Tesla will have a higher capture success percent in qualifications than Newton
TRUE 24. Tesla will have a lower challenge success percent in finals than Newton
Einstein
TRUE 25. The red alliance will win Einstein
TRUE 26. An alliance with a total team number summation of less than 1500 will be on Einstein
FALSE 27. An alliance with a total team number summation of more than 7000 will be on Einstein
TRUE 30. There will be a score above 250 points on Einstein
234 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
100.00% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
Unread 18-04-2016, 16:45
BL0X3R BL0X3R is offline
AKA: Nick
FRC #4488 (ShockWave)
BL0X3R is on a distinguished road
FALSE 7. Tesla's blue alliance in finals will earn more points than its red alliance.
FALSE 8. Tesla's moat will be used more in qualifications than the ramparts.
Inter-division
FALSE 18. Carson will have a lower total breaches success percent in finals than Archimedes
TRUE 20. Carver will have a lower total scales success percent in finals than Galileo
Einstein
244 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
94.44% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
Carson Finalists (4488, 67, 225, 5659)
2x District Winner + Gracious Professionalism & Engineering Excellence, DCMP Finalist and Entrepreneurship
Galileo Finalists (1153, 4488, 1318, 1218)
2x District Winner + Chairman's & Industrial Design, DCMP Finalist and Quality Award
http://www.chiefdelphi.com/forums/image.php?type=sigpic&userid=74752&dateline=139804  7731 Oregon Rookie All Star, Curie Rookie All Star
Unread 18-04-2016, 16:46
seans341's Avatar
seans341 seans341 is offline
FRC #0341 (Miss Daisy)
seans341 is a jewel in the roughseans341 is a jewel in the roughseans341 is a jewel in the roughseans341 is a jewel in the rough
True 1. Carson's red alliance in qualification will earn more points than its blue alliance.
False 2. Carson's draw bridge will be damaged more than 30% of the time it is used in qualifications
True 3. Carver's blue alliance in qualification will earn more points than its red alliance.
True 4. Carver's cheval de frise will be damaged more when it is used in qualifications than the portcullis.
True 5. Hopper's red alliance in finals will earn more points than its blue alliance.
False 6. Hopper's rough terrain will not be damaged in 2 or more qualification matches.
True 7. Tesla's blue alliance in finals will earn more points than its red alliance.
True 8. Tesla's moat will be used more in qualifications than the ramparts.
Flase 9. Archimedes' red alliance in qualification will earn more points than its blue alliance.
True 10. Archimedes' sally port will be damaged more than 55% of the time it is used in qualifications.
True 11. Galileo's blue alliance in qualification will earn more points than its red alliance.
False 12. Galileo's rock wall will not be damaged in 4 or more qualification matches.
True 13. Curie's red alliance in finals will earn more points than its blue alliance.
True 14. Curie's low bar will be damaged 100% in finals.
True 15. Newton's blue alliance in finals will earn more points than its red alliance.
True 16. Newton's moat will be used more in qualifications than the rough terrain.
Inter-division
False 17. Carson will have a higher challenge success percent in qualifications than Archimedes
False 18. Carson will have a lower total breaches success percent in finals than Archimedes
False 19. Carver will have a higher total breaches success percent in qualifications than Galileo
True 20. Carver will have a lower total scales success percent in finals than Galileo
False 21. Hopper will have a higher scales success percent in qualification than Curie
True 22. Hopper will have a lower capture success percent in finals than Curie
True 23. Tesla will have a higher capture success percent in qualifications than Newton
False 24. Tesla will have a lower challenge success percent in finals than Newton
Einstein
False 25. The red alliance will win Einstein
True 26. An alliance with a total team number summation of less than 1500 will be on Einstein
True 27. An alliance with a total team number summation of more than 7000 will be on Einstein
True 28. There will be a 3rd match in the finals on Einstein
True 29. There will be 4 teams scaling in a quarter finals match on Einstein
False 30. There will be a score above 250 points on Einstein
192 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
94.1% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
Additional prediction: The winning score of the final Einstein match will be 210.
Unread 18-04-2016, 16:54
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
TRUE 10. Archimedes' sally port will be damaged more than 55% of the time it is used in qualifications.
Inter-division
FALSE 22. Hopper will have a lower capture success percent in finals than Curie
Einstein
203 - Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
100.00% - Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 18-04-2016, 17:00
Jcarbon Jcarbon is offline
FRC #3322 (Eagle Imperium)
Jcarbon has a spectacular aura aboutJcarbon has a spectacular aura about
FALSE 3. Carver's blue alliance in qualification will earn more points than its red alliance.
TRUE 6. Hopper's rough terrain will not be damaged in 2 or more qualification matches.
Inter-division
Einstein
215 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
Unread 18-04-2016, 17:01
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
Inter-division
Einstein
0 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
94.74% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
Unread 18-04-2016, 17:15
M217's Avatar
M217 M217 is offline
#TSIMFD
AKA: Muhammad Mousa
FRC #3419 (Rohawks)
Team Role: Tactician
M217 is on a distinguished road
Let's see...
TRUE 19. Carver will have a higher total breaches success percent in qualifications than Galileo
235 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein.
100.00%Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth.
Unread 18-04-2016, 17:39
Moskowapplepi's Avatar
Moskowapplepi Moskowapplepi is offline
FRC #2067
Moskowapplepi is an unknown quantity at this point
False 1. Carson's red alliance in qualification will earn more points than its blue alliance.
False 4. Carver's cheval de frise will be damaged more when it is used in qualifications than the portcullis.
True 6. Hopper's rough terrain will not be damaged in 2 or more qualification matches.
False 8. Tesla's moat will be used more in qualifications than the ramparts.
True 9. Archimedes' red alliance in qualification will earn more points than its blue alliance.
False 11. Galileo's blue alliance in qualification will earn more points than its red alliance.
Inter-division
True 18. Carson will have a lower total breaches success percent in finals than Archimedes
False 20. Carver will have a lower total scales success percent in finals than Galileo
True 21. Hopper will have a higher scales success percent in qualification than Curie
False 22. Hopper will have a lower capture success percent in finals than Curie
True 24. Tesla will have a lower challenge success percent in finals than Newton
Einstein
True 25. The red alliance will win Einstein
True 30. There will be a score above 250 points on Einstein
185 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
91.33% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth.
Unread 18-04-2016, 17:55
Hgree56's Avatar
Hgree56 Hgree56 is offline
AKA: Hunter Greene
Hgree56 will become famous soon enough
Inter-division
Einstein
168 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
94% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
Just my guess.
2016 Indiana Tipp. District Industrial Safety Award winner
2016 Indiana Perry M. District QF w/ (3487 & 4580)
2015 Indiana Purdue District Chairman's Award winner
2015 Indiana Indianapolis District QF w/ (5403 & 4008) and Industrial Safety award winner
2015 Indiana Indianapolis, Purdue, and State Champs Industrial Safety Award Winner
2014 Crossroad GP Award Winner
2014 Boilermaker SF w/ (337 & 4213)
Unread 18-04-2016, 18:08
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
TRUE 2. Carson's draw bridge will be damaged more than 30% of the time it is used in qualifications
FALSE 11. Galileo's blue alliance in qualification will earn more points than its red alliance.
Inter-division
Einstein
240 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
89.99% Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
Unread 18-04-2016, 18:30
Liam Fay's Avatar
Liam Fay Liam Fay is offline
FRC #2485 (W.A.R. Lords)
Rookie Year: 2015
Liam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond reputeLiam Fay has a reputation beyond repute
Inter-division
Einstein
100 Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
Engineering Inspiration
San Diego 2016
Engineering Inspiration Orange County 2016
Industrial Design Carson Division 2016
Unread 18-04-2016, 19:16
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
Inter-division
Einstein
FALSE 28. There will be a 3rd match in the finals on Einstein
225 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
Unread 18-04-2016, 19:37
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Inter-division
Einstein
TRUE29. There will be 4 teams scaling in a quarter finals match on Einstein
180 Tiebreaker: Guess the score of the losing alliance of the final match on Einstein. Closest without going over wins
100.00 Tiebreaker2: Guess the total breaches success percent on Einstein to the nearest hundredth. Closest wins.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
