Go to Post Students, mentors, schools, corporations, teams, and communities - they are all critical to the success of FIRST. . - dlavery [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia > Fantasy FIRST
  #376   Spotlight this post!
Unread 16-04-2016, 19:37
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Re: [FF]: 2016 Season Long Fantasy FIRST
Originally Posted by ttldomination View Post
Just as a heads up; I'll have to add this as a special case to the live scoring, but the actual change may have to wait until I see some sample match data start flowing through the API.
Last year, the "Octofinals" flowed through as regular qualification matches, which may severely complicate things. Let's hope that Octofinals flow through as their own set of playoff matches.
- Sunny G.
Octofinal scoring hasn't been implemented yet.
I have updated the live scoring sheet and will do so again after matches finish today. Regular season scoring won't be truly final until Sunny gets to it, just a heads up.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
  #377   Spotlight this post!
Unread 16-04-2016, 21:44
ghostmachine360's Avatar
ghostmachine360 ghostmachine360 is offline
Kyle J. Fender
AKA: Kyle J. Fender
FRC #1002 (CircuitRunners Robotics)
ghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond repute
There were some problems with the API with the octofinals; Frank Merrick was dealing with it at PCH with Danny, but it should be fixed now, in theory.
Member of the Rotten Fruit Alliance
2013, 2015, & 2016 Fantasy FIRST Elgin Clock Award Winners [RFA]
2015 & 2016 Fantasy FIRST Champions [RFA]
GeorgiaFIRST Advisory Board & District Planning Commitee Member
SPSU Class of 2016: Robotics Engineering Major
GeorgiaFIRST FRC/FTC Emcee, FTC Head Referee, & FRC Referee
2010 CMP FRC Dean's List & 2010 Peachtree DLA Finalist
  #378   Spotlight this post!
Unread 16-04-2016, 23:50
Not a problem, fellas. I don't expect we'll need the finishing order until at least Wednesday (when we'll need it to set up the Championship drafts).
  #379   Spotlight this post!
Unread 17-04-2016, 08:09
ttldomination's Avatar
Sunny
I've implemented the Octofinalist logic for MSC.
It should be good/correct, but I threw it together quickly at the airport. As such, I'd appreciate if someone could double check the work and make sure the numbers make sense.
Thanks,
- Sunny G.
1648: 2013-2014
5283: 2015
  #380   Spotlight this post!
Unread 17-04-2016, 13:58
Thanks,
- Sunny G.
I verified MSC scores. Looks like you implemented Octos fine, but perhaps forgot to change the QF values from 4 to 6? Are all QF values differing from the usual at MSC?
We'll just do the same thing, QFs at MSC are 6 points and OFs are 3 points. Only at MSC, mind you.
*Elims portion of my MSC manual scoring attached*
Founding Member
  #381   Spotlight this post!
Unread 17-04-2016, 16:10
Sunny
Ah, okay. Found an issue where MSC teams were still being awarded QF along with the Octo-Quarterfinalist.
Should be fixed,
- Sunny G.
1648: 2013-2014
5283: 2015
  #382   Spotlight this post!
Unread 17-04-2016, 21:44
Before scores are final, Brennan noted today that there are two No-Shows on rosters for the PCH DCMP that need to be swapped for randoms. No random list is posted, do you have it Eric?
Swamp Life: 3635
The ULCAN: 5594
Founding Member
  #383   Spotlight this post!
Unread 17-04-2016, 21:46
Swamp Life: 3635
The ULCAN: 5594
3635
5594
1002
5632
5482
1261
4193
5812
5608
4188
5900
4749
4941
4468
5074
5132
3581
3600
5651
6023
5840
3329
1746
6177
5332
1648
4189
2415
5536
4026
3091
2974
1311
5848
4910
4240
4701
4080
4516
5582
5004
1771
832
5828
  #384   Spotlight this post!
Unread 17-04-2016, 22:00
Done.
Out: 3635 and 5594
In: 5608 and 4749
Scores should be final.
Founding Member
  #385   Spotlight this post!
Unread 18-04-2016, 21:37
Well, there goes THAT plan.
http://www.firstinspires.org/robotic...ip-lineup-show
Given that we won't know divisions until Friday...
I think we're going to need some planning. CMP starts Wednesday, but NOBODY wants to draft then. Travel, opening the pits, you get the idea.
That leaves Friday right after divisions finish announcing (yeah, right--8:30 Eastern at a guess, with no time for a picklist), Saturday, Sunday, Monday, and Tuesday (when folks are packing/traveling, so it's lousy).
Guess what that means?
THREE-A-DAYs.Well... Maybe not.
I should going to be able to run a draft every night except maybe Saturday. But, if y'all don't object, I can probably sneak a Saturday afternoon/evening draft in (as in, probably about 5 PM Eastern or a bit before). And, the draft schedule ain't changin'. So other than the times for a Saturday afternoon-ish draft, I can post all the subdivisions I'll be running at once (less team list) and when they'll be active. If someone else can take a draft each day, we should be A-OK.
Add to that that I'm fairly confident I can run two drafts at once if need be...
So, short version:
I'll post 4 draft orders for 4 of the subdivisions later this week. Pick all at once or one at a time, your choice, once the division lists are out. If someone can handle the second draft each day, great; if not, let's hope the posted orders go quickly...
  #386   Spotlight this post!
Unread 19-04-2016, 03:18
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
So, short version:
Can't we just post all of the drafts up Friday and work on them all simultaneously while certain ones have a deadline on "x day"?
TBC would be willing to help run drafts so that we can have all 8 division threads up at once. I feel like that would actually help speed up some of the process.
I propose:
Archimedes - Deadline April 23
Carson - Deadline April 23
Carver - Deadline April 24
Curie - Deadline April 24
Galileo - Deadline April 24
Hopper - Deadline April 25
Newton - Deadline April 25
Tesla - Deadline April 25
Being a 2/3/3
With all drafts going up the 22nd
Drafts on the 22nd is bad, and going to the 26th is also bad.
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
  #387   Spotlight this post!
Unread 19-04-2016, 14:41
I'm comfortable with both concepts, you've got my help either way. Just let me know which drafts you want me to run and when.
RFA will get all our first picks ready to submit shortly after divisions release. This way Broconnor and TBC can jump on with picks ahead of schedule if they like. Having all 8 posted for early drafting would be nice.
Founding Member
  #388   Spotlight this post!
Unread 19-04-2016, 20:04
You know, I like that idea even better.
So, I'll post all 8 drafts up tonight, without teams. (Just to make sure everything's correct as far as order, and have them ready to go.)
As soon as we have the teams (or shortly afterwards--I've got a team meeting on Friday at that time), team lists go on, randoms get generated and posted. Miss your slot on the date, get a random so we can move on.
I'll be sending a reminder to some folks who seem to have fallen asleep to wake up so we don't have to randomize them...
  #389   Spotlight this post!
Unread 22-04-2016, 23:04
RFA has submitted all 8 of our first picks. Let the madness begin
*Eric, let me know what drafts you need me to run
Founding Member
  #390   Spotlight this post!
Unread 22-04-2016, 23:51
We'll see how it goes, but tomorrow night is probably the primary night I'll need backup.
I'm going to get the team lists and random lists into the threads now, which will take *few* minutes... That should allow for full manual drafting if necessary. [Edit] And everything is up, team list, first pick, and the random list.
