Go to Post Why did they get rid of the headphone jack though? =p - sportzkrazzy [more]
Unread 19-04-2016, 01:24
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
Re: Do you think a jaguar will run for a few days constant?
Originally Posted by pilleya View Post
It should be fine a Neverest motor is only 14watts so just a bit over 1 amp current draw. I would suggest adding another fan, to cool it as the Jaguar fan is dynamic.
Have you considered that maybe it is your spool holder which is causing the problem, maybe a lower friction one could reduce your problem.
*Sorry this is slightly off-topic*
14 watts is the maximum output (mechanical) power of the motor, not the input (electrical power). The electrical power needed to generate this is actually 69 watts, or 5.75 amps (half of the stall current) at 12V.
For continuous applications like the OP's, I'd recommend running at peak efficiency, which means drawing ~1/5 of stall current or ~2.3 A. Of course, in the worst case the motor will somehow jam and stall, in which case it will draw the full stall current of 11.5 A, which is still well within limits of the Jag, but the motor may not be so happy. A fuse/breaker or smart current limiting using the Jag's current readout can save your motor in this case.
VEX's motor page has a pretty good introduction to (brushed) DC motor theory/curves.
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
Unread 19-04-2016, 01:31
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Thanks for correcting me, yes I had over-looked that this is max power not power at maximum efficiency.
Facebook
Unread 19-04-2016, 06:31
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Wow! Thanks for the quick responses! I welded together a stand for the spool with ball bearings for it too roll on, it took the extruder all of about 5 minutes to ball up the hob. Thanks for all the help, I will make sure to keep everything well cooled.
Edit: This is probably happening because I run everything except the perimeter moves at 300mm/s
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
