Go to Post WE might have a different plan than being overweight, but thats just my guess - pakrat [more]
Unread 18-04-2016, 23:45
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Do you think a jaguar will run for a few days constant?
I am building a filament de-reeler for my 3d printer because my extruder cant pull the push plastic 10kg spool. so I figured I would use some stuff that I have laying around. I was gonna use a black jaguar, and a neverest FTC motor. The thing is, it will probably be running for 4 days straight, they wont be drawing much current, but I have doubts in my mind that they can take that... What do you guys think?
Thanks
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 19-04-2016, 00:27
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Do you think a jaguar will run for a few days constant?
I think it should work okay as long as the current is low. Keep the Jag in a well ventilated area so it doesn't overheat -- that (and water) is the main reason speed controllers fail. Specifically, don't block its fan or give it a good way to clog the fan's vent holes.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 19-04-2016, 00:48
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
It should be fine a Neverest motor is only 14watts so just a bit over 1 amp current draw. I would suggest adding another fan, to cool it as the Jaguar fan is dynamic.
Have you considered that maybe it is your spool holder which is causing the problem, maybe a lower friction one could reduce your problem.
Facebook
Unread 19-04-2016, 01:21
NerdRage's Avatar
NerdRage NerdRage is offline
Custom fabricated by @me
FRC #3863 (Pantherbotics)
Rookie Year: 2016
NerdRage is an unknown quantity at this point
Agreed that it may be the spool holder. Perhaps OP has some spare bearings that he could use and put the spool onto?
Unread 19-04-2016, 01:24
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
*Sorry this is slightly off-topic*
14 watts is the maximum output (mechanical) power of the motor, not the input (electrical power). The electrical power needed to generate this is actually 69 watts, or 5.75 amps (half of the stall current) at 12V.
For continuous applications like the OP's, I'd recommend running at peak efficiency, which means drawing ~1/5 of stall current or ~2.3 A. Of course, in the worst case the motor will somehow jam and stall, in which case it will draw the full stall current of 11.5 A, which is still well within limits of the Jag, but the motor may not be so happy. A fuse/breaker or smart current limiting using the Jag's current readout can save your motor in this case.
VEX's motor page has a pretty good introduction to (brushed) DC motor theory/curves.
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
Unread 19-04-2016, 01:31
pilleya's Avatar
Elec+Mech
Thanks for correcting me, yes I had over-looked that this is max power not power at maximum efficiency.
Facebook
Unread 19-04-2016, 06:31
teslalab2's Avatar
RogueBotix LLC
VRC #8091
Wow! Thanks for the quick responses! I welded together a stand for the spool with ball bearings for it too roll on, it took the extruder all of about 5 minutes to ball up the hob. Thanks for all the help, I will make sure to keep everything well cooled.
Edit: This is probably happening because I run everything except the perimeter moves at 300mm/s
