Go to Post Can't we also care about and celebrate the processes, the professionalism, the experience of healing? - Taylor [more]
  #31   Spotlight this post!
Unread 19-04-2016, 07:51
pfreivald's Avatar
AKA: Patrick Freivald
Re: pic: Stripped VexPro gear
Originally Posted by R.C. View Post
Jeff,
I totally agree with you, I thought we made this change over. I will check and get this implemented, also have a few other changes planned.
That's awesome, thanks!
(I'll probably still drill a bunch of holes in the steel, but will never go with aluminum gears in a drivetrain again.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #32   Spotlight this post!
Unread 19-04-2016, 08:15
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
We broke one at our district championship event. The interesting and slightly concerning thing is that it wasn't at a particularly high load, just a sustained, consistent torque load due to a misaligned limit switch. The gear that failed is driven by a PG27 with a 16t steel gear on the output shaft and is only driven at partial power.
Unfortunately there isn't a steel option like these: http://www.vexrobotics.com/vexpro/mo...ore-gears.html
We only use a portion of the gear's circumference to actuate our intake, so rotating the gear is an option we'll likely pursue at champs if we have the down time.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
  #33   Spotlight this post!
Unread 19-04-2016, 08:21
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Does the PG27 have a 9015 or a RS775-125, as there is a massive difference in torque and power output.
Facebook
  #34   Spotlight this post!
Unread 19-04-2016, 08:31
FRC #1747
RS775. It broke on the "down" actuation though, which is much lower applied power systematically. My guess is it's actually more related to shock load of the intake coming up against the hard stop that sets the height. It didn't affect our performance this time, so it isn't nearly as big of a deal.
