Go to Post I wanted to make an epoxy/carbon fiber/fiberglass arm for our 'bot, but I was outvoted by conservative teenagers. Oh well... - Rick TYler [more]
Unread 13-04-2016, 16:21
Ngang's Avatar
Ngang Ngang is offline
FRC #2265 (Fe Maidens)
Team Role: Electrical
Ngang is an unknown quantity at this point
How can Arduinos be integrated with the current electronic/control system?
Hey, my team is interested in building a custom electronic system during the post season. Have any of you utilized Arduinos to do this???
Unread 13-04-2016, 16:23
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: How can Arduinos be integrated with the current electronic/control system?
I made a system too replace the roborio with an arduino if thats what you mean
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 13-04-2016, 16:27
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We use an arduino to control our LED strips. roboRio sends signal to dio on arduino. Adruino changes color scheme based on dio signal.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 13-04-2016, 20:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have done a number of projects (most notably our air cannon) with arduino controls. They are a great way to control a robot on a much smaller budget that using a roboRIO. They interface easily with all of the PWM-based motor controllers, as well as the spike relay, and (through 12V relay modules) pneumatic solenoids, LEDs, and a wide variety of sensors. That is, they are a great low-cost replacement for the roboRIO in many applications where the RIO is a bit of overkill.
While it is certainly possible to communicate between arduino and cRIO/roboRIO computers using USB, serial I/O, I2C, and/or SPI, we have not found enough reason to justify the effort. This is because the thing that arduinos do so well is to provide a bunch of analog inputs, digital I/Os, and PWM outputs; these are all things which the RIOs natively do in sufficient quantity (and speed) for our needs.
We have successfully used raspberry pi as a vision processor on FRC competition robots. That is, we connect the camera directly to the pi (or on network in 2012-2014), and send data packets consisting of just a handful of numbers to the robot telling it where the target is located (header/sync, x, y, width, height). Offloading the vision processing to a device adjacent to the camera definitely reduces the required wireless network bandwidth and/or the CPU load on the RIO. (and vs or is based on your alternate solution.)
I guess the main thing to know as to how or if to integrate an arduino and a roboRIO boils down to the generic engineering question: what problem are you trying to solve?
Unread 14-04-2016, 07:33
Ngang,
Some of our students were involved with the school NJROTC group. NJROTC had an underwater comp and were building an underwater vehicle for that. One of our students was in both groups and we provided tech support for build and programming. An Arduino Uno was used for that purpose to supply signals for motor control using Victors and relays with a relay board.
Unread 14-04-2016, 13:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
You can control common FRC motor controllers using the Servo library and the Servo.writeMicroseconds() method. Write 1000 for full reverse, 2000 for full forward, and 1500 for neutral on most controllers. I've controlled Talon SRXs this way before with good results.
Unread 14-04-2016, 21:25
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
There are even full arduino based products and free libraries for using wifi to control robots with arduino.
We've been developing and selling these devices for several years. We sell complete robot controllers and also offer our communications library and driver stations for free to and Arduino user.
Learn more about RobotOpen here.
A custom swerve robot running Arduino based RobotOpen controls.
https://www.youtube.com/watch?v=hdAmpk0PQ3I
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 19-04-2016, 01:26
NerdRage's Avatar
NerdRage NerdRage is offline
Custom fabricated by @me
FRC #3863 (Pantherbotics)
Rookie Year: 2016
NerdRage is an unknown quantity at this point
Our team has interfaced an Arduino Mega to the RoboRio, through what I believe was the rX/tX pins of the Arduino (not sure, I wasn't in charge of that). We made sure to power the Arduino not through the Rio, but instead through a voltage step-down converter through the power expander. You have to go this route if you want to go LED strips, otherwise I can't think of anything else that would supply the amperage.
Unread 19-04-2016, 01:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Another option if you aren't locked into an Arduino is a CTRE Hero.
http://www.ctr-electronics.com/control-system/hro.html
Unread 19-04-2016, 08:36
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Tom,
Is there a link somewhere that discusses the pros/cons of the CTRE HERO development board vs the Aruduino family for those of us beginning down this embedded controller path?
I do have embedded controller experience but have been happy with the cRIO for FRC applicatons but would like to add vision processing to our FRC robot and the raspberry PI path seems to have some support.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
