#16
Re: First ever 70 point auto
A tremendous congratulations to 195 for getting their two ball auto working... it's an exceptionally difficult feat!
I think the vast majority of teams underestimate how difficult it is (this coming from a team that usually 'specializes' in auto, with things like a 5-ball auto in 2010, 4-ball auto in 2012, and 3-tote stack in 2015). Our robot quite frankly can't support the speed of actions necessary to make it work through the low bar. Not to mention that the two-ball auto almost neccessitates more unique driving patterns than many other "top notch autos" from previous seasons. As such, I definitely do not expect to see as many as 12 2-ball autos working at CMP. Perhaps as many as 12 teams attempting it... but there's a lot that separates a success from an attempt in this case! Quote:
We did very much like the defensive selection that 558's alliance developed in quarter finals against 195-125-2168... it constrained their autonomous routines to be clustered together and made the slot 2 auto a particularly difficult angle. Unfortunately though, the Drawbridge was the audience selection in semifinals, so that was locked into slot 3. If it weren't, we could've done either the same setup as QFs, or we could've placed Slot2: Drawbridge, Slot3: Portcullis, Slot4: Rock Wall, Slot5: Ramparts (which would've prevented the HP-courtyard throughway 195's HP maximized). An astute observer would have noticed though, that although 195 was able to roll as many as 10 balls through to the courtyard in SF2-2 (replay 2), they weren't nearly as proficient in QF3-2, SF2-1, SF2-2 (original), or SF2-1 (replay 1). I think as a benchmark SF2-1 had two successful bowls to the courtyard... which I think speaks even more to the 195 HP's skill, because he became so proficient at it so fast! An astute observer also would have noticed that after our SF2-2 auto scores were accepted, when SF2-3 was being set up (before SF2-2 was declared a field fault), we had changed the Defenses to prevent 195's highly capable HP... I believe we had Slot2: Portcullis, Slot3: Drawbridge, Slot4: Ramparts, Slot5: Rock Wall. Unfortunately for our alliance though, when SF2-2 was ruled a field fault and was replayed, we had to return to the Defense arrangement that 195's skilled HP loved. :-) Kudos to an alliance that makes you try to pick Defenses based off a killer autonomous and a tremendous HP... not just teleop cycling! |
#17
I still don't understand how he's able to consistently curve the ball over any passive defense/cheval de frise. He's even been practicing curving it directly out of the right of the secret passage, over our own first slot defense for it to roll over the third slot defense on the opponent's side. Dude's crazy.
#18
With 67s design, a 2 ball auto probably isn't out of question. Hope to see them get it going.
#19
If teams pay attention to their scouting data, they can make 70-pt autos seldom to appear again at champs by selecting defenses as was done in later matches at NE to cluster all alliance teams towards the low bar. After that 70-pt auto match, in later matches you can see 125, and 2168, tweaking their auto routines in order to prevent being effected by the defense cluster as much and giving 195 as much a change to pull of the 2-ball as possible. But after the 70-pt auto, in all of the matches we played after quarter finals. I think we had many 50-pt autos and a 40-pt auto. Not saying its impossible, but smart alliances will do everything from preventing an opponent alliance with even the chance of doing a 70-pt auto. On another note - 1519, 230, and 176 proved that even with a 50-pt auto, you can set the world high score. |
#20
Took all week but we finally made another 70 point auto on Einstein QF2-2.
Thank you to our partners 987 and 1197. https://youtu.be/8y8VaZzWNDw |
#21
#22
