Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 19-04-2016, 09:49
Metalcrafters Metalcrafters is offline
AKA: Lucas Pacheco
FRC #0207 (MetalCrafters)
Metalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond reputeMetalcrafters has a reputation beyond repute
pic: 3D printed beveled gears
Unread 19-04-2016, 09:50
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: pic: 3D printed beveled gears
We use prints for low stress applications. The fact that you powered your intake with bevel gears that were printed AND they held up to two regionals is amazing.
Print specs?
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 19-04-2016, 09:58
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Yeah... We tried this for a week or two, then they got absolutely destroyed after a few days of practice. We switched over to the VP steel bevels and they show little to no wear. I'm glad to see someone being successful in printing and using bevel gears on their intake .
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 19-04-2016, 10:40
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Mind if I ask what you're using for a printer/filament? We had a MakerBot donated last year, but the filament we have would never hold up under load.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 19-04-2016, 13:02
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
This is awesome that it worked well for you. Did you just take the STEP file of the WCP Bevel Gear and print that unmodified or did you mess with the CAD to optimize for Printing?
Unread 19-04-2016, 13:28
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
What rpm do they run at? Also what motor/gearbox combination are you using to drive them (and what ratio)?
Unread 19-04-2016, 13:29
Carolyn_Grace's Avatar
Carolyn_Grace Carolyn_Grace is offline
Build bridges not walls.
AKA: Carolyn Beyer
FRC #1024
Carolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond repute
Just pointing out how amusing it is that you're the MetalCrafters, and you have plastic gears.
"It is change, continuing change, inevitable change, that is the dominant factor in society today. No sensible decision can be made any longer without taking into account not only the world as it is, but the world as it will be." -Isaac Asimov
Unread 19-04-2016, 16:11
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
*Disclaimer - I am not from OP team.
We have a Makerbot Replicator 2x. Last year we invested in carbon fiber reinforced filament and it is amazing!! Cleaner print than ABS and stronger. Depending on infill can be a little brittle but has held up under lots of applications.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Last edited by rsegrest : 19-04-2016 at 16:11. Reason: Added make and model of 3D printer
Unread 19-04-2016, 16:18
Pauline Tasci's Avatar
Pauline Tasci Pauline Tasci is offline
Rockets and Robots
FRC #3476 (Code Orange)
Pauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond repute
I tried printing the same bevel gears for our intake last year, the were constantly being used, they melted within a couple practice matches, so we switched to metal.
Awesome to see it worked for you guys, but make sure to keep your eyes on them!
Team 3476 Code Orange- 2014-? ~ Head Mechanical and Design Mentor
FIRST Orange County 2015-? ~Regional Planning Committee Member
Beach Blitz 2016-? ~ Event Chair/Director
FIRST Volunteer-2010-?
Team 589 Falkon Robotics- 2010-2013 ~Captain, Driver, Outreach, Mech Lead
CD Moderator~ Always feel free to PM me.
Facebook
Unread 19-04-2016, 16:23
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
The whole collector is driven off of a BAG on a Versaplanetary with..... I believe a 100:1 reduction then a (minor) multiplier with an 18t vex gear on the output of the planetary and a 16t on the input of the collector driveshaft. I actually don't remember what the reduction in the VP gearbox is, I'll check whenever I end up back at the shop.
Lucas should be back here to answer any questions about the printers we use.
¯\_(ツ)_/¯
Unread 19-04-2016, 17:35
AKA: Topher
no team (WildStang)
Team Role: CAD
I know you didn't necessarily ask me, but what I did was I changed the regular VEXPro 15t 20DP bevel gear file to be a 5/16" hex instead of a 3/8" hex. I also removed the bottom step-in on the bevel for a better print. The 5/16" hex allowed us to run hex inside of a 9mm ID 17mm OD ball bearing from McMaster (7804K148).
Unread 19-04-2016, 17:48
AKA: Lucas Pacheco
It is funny that we are the metalcrafters and print a great deal of parts. We have been printing parts for load applications for years. We have learned how to design for the machine.
This is what our list of printed parts looks like for this year:
2 pcs wheels with 1/2 hex for the pneumatic tires. Started with 6 spoke reduced them to 4. We feel from the tower while lifting bent the axles all the wheels were perfect.
Bearing holders and drive plugs for all of the intake rollers.
Spools for constant force springs
CIM adaptor for a 18 tooth hex sprocket
Pitching Wheel hex adaptors
All of our parts we print are from a Uprint running ABS. I am sure these gears had solid infill. We are lucky enough to have 2 Uprints. We are currently hooking up a large format machine Fortus 400MC, let see what we come up for next year.
I hate to say it, but we downloaded the step file from VexPro and hit print(no modifications). Our original intent was to use the steel gears, but being over weight this year we were digging deep. We thought we were going to have to replace them every so many matches, never happened. I am sure they would last all season if it wasn't for hitting the wall.
Lucas Pacheco
Instructor/Team Manager
Manufacturing Engineer
Hawthorne High
School of Manufacturing and Engineering
HHSEngineering.com
