Go to Post FIRST needs a disclaimer that parts of the field can become flying projectiles under hurricane force winds. - Barry Bonzack [more]
Unread 22-01-2002, 12:58
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
i wish that the pumps we have did have a pressure input on them... if it did then we could bleed the pressure from an extended but retracting cylinder back into the pump to make its work easyer. kinda like a closed system.. but I can see problems with it too..
you would need a popoff valve on the return pressure side to prevent the return and the supply from equalizing and freezing the cylenders untill the compressor could lower the pressure in the return side.
but its all a moot point cause the compressor doesent have that input, and we cant make a fitting for it to have...
tho another interesting idea is to use exuasted cylender air to cool your motors.. I mean it was cooled when it expanded from the cylender and its going to waist if you dont do somthing with it..
ohwell.. just a few thoughts.. take them as you will
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Who has used pneumatic wheels? chellyzee93 Kit & Additional Hardware 3 16-02-2003 11:49
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Pneumatics and last year's storage tanks Darwin695 Pneumatics 3 04-02-2003 02:13
pneumatic system pressure illumanat'i Pneumatics 6 31-01-2003 00:46
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
