Go to Post If you do mentor FIRST, be an asset to your team, but know that your students will admire you all the more if you set an example and finish your own homework. - Eugenia Gabrielov [more]
Unread 16-02-2016, 10:10
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: The Pulsinator is Here!
Originally Posted by Spinoff View Post
Darn! I hope that the Thrifty Throttle has met your needs.
It has. We might buy more of them next year. So, if you can get it to accept 12 volts, that would be a reason to buy yours.
It would also be great for motorizing a cart that I have been thinking about doing.
Unread 16-02-2016, 11:37
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Darn! I hope that the Thrifty Throttle has met your needs. One of the coolest things about the Pulsinator is that the profits generated through this product are used to sponsor other robotics teams! In a way, you are buying a useful tool and helping other teams to succeed.
In the same way, AndyMark helps sponsor teams.
461 Westside Boiler Invasion
45 Technokats
Unread 16-02-2016, 12:08
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Now if somebody can make it work for CAN bus.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 19-04-2016, 23:51
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
Can you use it with a PWM splitter to run two motor controllers simultaneously? This would have been very helpful when prototyping shooters this year.
Unread 20-04-2016, 13:24
It might depend on what motor controllers you are using. The different motor controllers have widely different input impedance.
Unread 21-04-2016, 10:55
Drive Coach
AKA: Alex Dalziel
Team Role: Driver
We would use Talons like the ones recommended.
Unread 21-04-2016, 11:35
Which Talons?
Recommended by whom?
Unread 21-04-2016, 23:35
Drive Coach
AKA: Alex Dalziel
Team Role: Driver
Just the old Talons, the ones recommended both in this thread and on the website.
Unread 22-04-2016, 00:03
Three things:
1) FTR, there are two different models of 2016-FRC-legal "old" Talons.
2) The only other mention of "Talon" in this thread was the OP, wherein old/new was not explicit.
3) I'm told by Spinoff that the Pulsinator is capable of 40ma output. I assume that's with a dead short. Still, it should be adequate to control two of the older Talons (original or SR) with a splitter. Try sending a PM to Spinoff to confirm.
Unread 22-04-2016, 17:14
Drive Coach
AKA: Alex Dalziel
Team Role: Driver
Thank you. I did not realize there were two types of the 'old' talons.
Unread 24-04-2016, 09:09
tpope tpope is offline
AKA: Thomas Pope
FRC #3504 (Girls of Steel)
tpope is an unknown quantity at this point
We built a motor test board with an old (circa 2013) power distribution board, main breaker, a few talons and a small PWM generator that fed off the 5V rail. I don't recall the brand, but it had a 1.5" boxy yellow enclosure. We were never able to split the signal three ways, but on good days can run two talons at once off the thing.
It's been a useful tool, though quite bulky of course.
With a test board like that in mind I would second the request for either 12v or 5v input, ideally with a standard radio connector. I would also love something that had three PWM outputs and could drive all of them at once with the same signal. When we want to test a 3-CIM gearbox for instance, having all three motors running at the same speed is pretty important. Call that one the Pulsinator Pro and include mounting points and instructions for test board creation. I'm sure lots of teams have a big box of pre-2015 controllers and power boards they could use for this, and in situations like that there is some value in having a full setup like that.
On the flipside, what you are going for is a worthwhile exercise (eliminating extra bulk and cables) but I'd love to see you go one step further. What I really want for quick testing in the pit would be something that is in essence just one single, somewhat lumpy cable. On one end we have a battery connector and on the other we have wires that we can terminate how we please. In the middle we have the controller package.
In the short term, perhaps selling (or even just publishing STL files for) a custom bracket that would let you snap the Pulsinator in one side and bolt an old Talon SR or maybe new Spark motor controller on the other side would work. Attach the two together and then wire on the outside.
In the longer term, perhaps work with Rev Robotics and see if you could build a custom enclosure that housed the guts of both the Pulsinator and their Spark, with internal wiring. That would give you a clean single-package solution.
Actually, we might just pick up a couple and play around with this as a summer project. Might be fun...
Either way, it's great to see more options like this available!
Unread 24-04-2016, 12:56
Aren Siekmeier's Avatar
on walkabout
For something like this, you can take an old 12V hand drill (or other power tool), remove the motor, and terminate those wires however you like. The trigger gives you variable control over the supplied voltage, and the switch reverses it! Battery included, all in one handheld device. Hook it up to the motor and you're good to go. Downside is that you probably only want to run one large motor off of it...
