Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 19-04-2016, 19:34
crazedmummy crazedmummy is offline
FRC #0904
crazedmummy is an unknown quantity at this point
pic: 904 hangs in there
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Re: pic: 904 hangs in there
My goodness those omnis are huge. Where did you get them?
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 19-04-2016, 20:59
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
I see your gigantic Omni wheels and raise you 4915
http://www.thebluealliance.com/team/4915
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 20-04-2016, 07:52
adam the great's Avatar
adam the great adam the great is offline
Strategy Mentor
AKA: Adam Brewster
FRC #2168 (Aluminum Falcons)
adam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud of
Wow those are some massive wheels!
~Adam Brewster~
2168 (Drive Coach/Strategist)
Past Teams: 1930, 2228, 229, 4124, 5240#NeverForget4124
Last edited by adam the great : 20-04-2016 at 10:15. Reason: Mistaken interpretation
Unread 20-04-2016, 07:58
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Originally Posted by adam the great View Post
Wow those are some massive wheels, I assume they were eventually told that their hang gets them penalties?
How does it get them penalties? If they drive up to the castle then pull the arm in, they would never be extending over 15" beyond the frame perimeter because the arm goes inside the frame perimeter.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 20-04-2016, 08:16
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
I am told they custom built the Omni's.
Nice hanging, 904. It was fun to watch at our events!
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 20-04-2016, 10:13
Strategy Mentor
AKA: Adam Brewster
Thumbs up Re: pic: 904 hangs in there
Oops my mistake, last I checked I thought the interpretation of the 15" while climbing orientation thing was slightly different. As most robots would have had to leave the 15" while rotating up the tower, you are correct. Oops
~Adam Brewster~
Unread 20-04-2016, 10:32
ConnorTheCoch ConnorTheCoch is offline
Have You Turned It Off And Back On?
AKA: ( ͡° ͜ʖ ͡°)
no team (Baby Dean)
Team Role: Team Spirit / Cheering
ConnorTheCoch is infamous around these partsConnorTheCoch is infamous around these parts
Indeed, you guys are hanging in there as a leaf hangs from a tree. This engineering ascent is spectacular and I applaud team 904 for climbing to new feats. To this day, Isaac Newton would be proud of such a physics feat, scaling a barbaric tower to capture their tower and land is something that even Newton would crack a smile to.
TL;DR Congrats on scaling, I will catch you guys at World Championships to see your feats.
