Go to Post It's a FIRST thing. You gots to understand. - Koko Ed [more]
Unread 19-04-2016, 21:27
BenHildy's Avatar
BenHildy BenHildy is offline
Eyes in the Sky
AKA: Ben Hildebrandt
FRC #2169 (KING TeC)
Team Role: Tactician
BenHildy is on a distinguished road
Re: Tower Strength Raised to 10 for CMP
Ok I honestly don't think that this will make a huge difference in score, especially in matches with high tier teams (which will be quite often as it is world's). I say this because from what I've seen, at least at many competitions nationwide, a -2 or lower tower strength is not entirely uncommon. When it comes to low-goal cyclers vs high goal ones, however, I do see a bit of an advantage on the low-goal robots because of the speed and efficiency they bring to the table. High goals are easier to defend against and are statistically less accurate. However, the scores will not be affected in my opinion. Since balls still count as scored even when the tower is decreased below zero, the alliances will simply gain the Capture later in the match as opposed to after the eighth shot (which has recently occurred pretty early).
2013-2014: FTC 5330 Robotic Rush (Drive Coach | Programmer)
2015-Present: FRC 2169 KING TeC (Strategist | Qualitative Scouter)
Unread 19-04-2016, 22:13
wjordan wjordan is offline
FRC Stathead
AKA: Wes Jordan
FRC #2363 (Triple Helix)
wjordan is a jewel in the roughwjordan is a jewel in the roughwjordan is a jewel in the roughwjordan is a jewel in the rough
The lines show the percent of half-matches with a certain score that damaged the tower to a certain degree.
This leads me to believe that increasing tower strength may be a fairly big deal in qualifications (where match scores should hang around in the 100-150 range), but no so much in eliminations, where teams should be able to put up 120+ without the breach/capture bonuses.
2016: Northern Virginia Winners (1418, 2421), Hampton Roads Finalists (1885, 5954)
2015: Virginia Winners (384, 1610), Chesapeake Winners (1690, 4050)
2014: Chesapeake Winners (1629, 623), Galileo Winners (67, 973, 2481)
2013: Virginia Finalists (2053, 3015)
Unread 19-04-2016, 22:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This leads me to believe that increasing tower strength may be a fairly big deal in qualifications (where match scores should hang around in the 100-150 range, but no so much in eliminations, where teams should be able to put up 120+ without the breach/capture bonuses.
I'm actually curious how this change would have affected DCMPs. It'd be interesting to see how the rankings would shuffle with 10 tower strength instead of 8. Keeping in mind that average quality at DCMPs is usually much higher than at CMP.
Unread 19-04-2016, 22:30
Van.Augur Van.Augur is offline
FRC #4557 (FullMetal Falcons)
Van.Augur will become famous soon enough
Seems like a pretty straightforward change. In the New England District at least, by the latter end of competition season (and especially at District Champs) you were regularly seeing both alliances get the breach ranking point every single match. It often came down to which team could score more boulders. Increasing the tower strength only seems to up the ante. It's obviously going to favor the teams who can score quickly and consistently. As others have said, having a tower score <-2 wasn't particularly uncommon amongst the upper caliber of teams, so I'm skeptical about the magnitude of change this rule will make. I think the obvious conclusion is that it will separate the good/quick shooting bots from the exceptional/rapid shooting bots. Things like 2-ball autonomous code will be even more valuable going into worlds.
Unread 19-04-2016, 23:16
FRC Stathead
AKA: Wes Jordan
I wrote a script to calculate just that. Here's MSC, for example:
New Rank, Team, New Rank Pts, Spots Changed
1 frc2767 44 0
2 frc3620 42 7
3 frc4967 42 3
4 frc2771 41 7
5 frc4003 41 -2
6 frc5150 41 -2
7 frc33 41 3
8 frc27 39 -6
9 frc494 38 5
10 frc1023 38 7
11 frc5980 38 -6
12 frc1918 37 -4
13 frc67 37 0
14 frc6086 37 17
15 frc5050 37 0
16 frc573 37 8
17 frc3641 37 -1
18 frc70 36 -11
19 frc5053 36 0
20 frc858 35 9
21 frc3688 34 1
22 frc5505 34 1
23 frc2474 34 -11
24 frc4391 33 -3
25 frc548 33 13
26 frc107 33 19
27 frc1701 33 6
28 frc5048 33 -3
29 frc5712 33 19
30 frc3534 33 -10
31 frc3548 33 31
32 frc2834 32 -2
33 frc3098 32 6
34 frc51 32 8
35 frc4362 32 -17
36 frc3604 32 -8
37 frc1481 32 22
38 frc5460 32 -12
39 frc3546 31 -2
40 frc2054 31 9
41 frc5084 31 -14
42 frc217 31 -1
43 frc5878 31 -11
44 frc3357 31 -1
45 frc3234 31 2
46 frc3452 31 -10
47 frc2619 30 -7
48 frc3655 30 8
49 frc1684 30 -3
50 frc3536 30 14
51 frc1250 30 1
52 frc3618 29 1
53 frc5448 29 -9
54 frc5167 29 -3
55 frc3602 29 6
56 frc2586 28 -6
57 frc4377 28 -2
58 frc85 28 0
59 frc2337 28 1
60 frc3539 28 9
61 frc3770 28 -26
62 frc6098 27 -5
63 frc6193 27 -29
64 frc2612 27 3
65 frc3707 27 3
66 frc3656 26 21
67 frc4384 26 -13
68 frc74 26 10
69 frc4216 26 -6
70 frc5907 26 13
71 frc68 26 8
72 frc1718 26 0
73 frc5230 26 17
74 frc1025 26 2
75 frc1711 25 -4
76 frc4776 25 8
77 frc503 25 -3
78 frc6121 25 3
79 frc4680 25 14
80 frc3414 24 -10
81 frc6075 24 -1
82 frc5155 24 4
83 frc2137 23 -6
84 frc123 23 -2
85 frc2604 23 -12
86 frc2611 23 9
87 frc5166 23 -22
88 frc5114 23 -22
89 frc5203 22 -1
90 frc66 22 -1
91 frc3668 22 -16
92 frc3886 22 -1
93 frc4381 21 5
94 frc6097 21 -9
95 frc2959 20 1
96 frc5222 20 -2
97 frc3538 20 -5
98 frc5502 19 -1
99 frc1322 19 3
100 frc5090 19 0
101 frc3767 18 0
102 frc5926 18 -3
Unread 19-04-2016, 23:28
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
This would certainly have created a very different draft!
However, I suspect higher tower strength would also have caused several teams to play differently.
I look forward to the style of play this change will cause at CMP.
Richard Wallace
since 2003
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Hope so
"A genius is just a talented person who does his homework" T. Edison
Unread 19-04-2016, 23:43
Amit3339 Amit3339 is offline
B B BumleB
FRC #3339
Amit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to behold
First of all I gotta say i'm pretty happy with increasing the tower strenght to CMP. I was sure that the defences strenght will increase as well because of it...
I don't think this action will effect the low goal robot from the main reason that if you can capture the tower if can get the RP and if you can't you just won't. I't dosen't has anything to do with where you score the boulder, it's all about if you can score 10 boulders in the tower and unfortunately this will effect many teams during the entire CMP.
Whenever it comes to playoffs I believe that the tower health will be down by every game but the real question that still keeps the capture precent pretty low is will the tower will be captured? Will all the teams will be on the batter? That's the biggest misery
2016- Team Captain, Driver & Programming Crew Member
Championship Curie Sub-division Winners| Curie division
Regional Winners | Israeli Regional
2015- Driver & Programming Crew Member
Championship Carson Sub-division Winners| Carson division
Excellence in Engineering Award sponsored by Delphi | Israeli Regional
2014- Driver & Programming Crew Member
Unread 20-04-2016, 01:53
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Originally Posted by CalTran View Post
Assumedly this would be a G11 infraction.
Imo, putting a boulder in your own defenses would not be a G11 infraction by itself. G11's blue box says
G11 requires an intentional act with limited or no opportunity for the TEAM being acted on to avoid the penalty.
Putting a boulder in your own defenses would be a valid defense strategy then, since the opposing robots can choose to slow down and clear out the boulder to avoid the foul. As I see it, the difference is that the opposing alliance is not forced into committing a foul.
Disclaimer: Just a student's interpretation of the rules. The refs may call it differently.
Unread 20-04-2016, 07:34
Originally Posted by Chak View Post
Imo, putting a boulder in your own defenses would not be a G11 infraction by itself. ...
Read one rule further.
G12-1 ROBOTS may not deliberately use FIELD elements, e.g. BOULDERS, in an attempt to ease or amplify the challenge associated with other FIELD elements, e.g. DEFENSES. Violation: FOUL. For every five (5) seconds in which the situation is not corrected, FOUL
And its Blue Box:
Example actions that violate G12-1 include, but aren’t limited to the
following: adding BOULDERS to your Moat to make it harder for your
opponents to CROSS the Moat, using a BOULDER to prop up Cheval
de Frise elements, propping open a DEFENSE door with a BOULDER.
Richard Wallace
since 2003
Unread 20-04-2016, 07:38
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
I think you all are missing a very valid point. Consider this:
A consistent, accurate high goal shooter, spends a lot of time chasing down boulders. A consistent, fast, robot that can breach most outer works can feed the high goal shooter. Get a ball, drop it in front of the high goal shooter and go get another one. Repeat the cycle. Quickly. Two things happen, the outer works fall and the cycle time for high goal scores drop. Scores go up. Discuss.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 20-04-2016, 09:26
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
What is the third robot doing in this situation? If there is a good defender against the high goal shooter who can do something with the boulders that the feeder bot brings, it would cause the shooter to go chasing boulders down instead of shoot, load, rinse and repeat.
EDIT: Third bot could draw the defender's attention away from the shooter and allow it to do its thing, or remain undefended and make up for the lost cycle time. If the third bot is playing defense, I feel this strategy would get shut down pretty quickly.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Last edited by Eric Scheuing : 20-04-2016 at 09:27. Reason: Forgot to finish my point.
Unread 20-04-2016, 09:28
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
If you had a reliable shooter whose limiting action is its defense crossing ability, you could consider running the third robot in tandem with your shooter, setting picks and crossing defenses, but not manipulating balls.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
Unread 20-04-2016, 10:02
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
Director
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Breakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really nice
One of the things you have to remember about low vs high is that it takes 2.5 low goals to = 1 high goal. Look at the following situation. One alliance scores 10 boulders all in the low goal in elims this = 45 points. The opposing alliance shoots just 9 but all high goals this = 45 points. A low goal shooter is really valuable for bringing down the tower, but it is going to take the high goal to win divisions or Einstein. If the high goal shooting alliance previously mentioned scores just one more ball, the swing is 30 points. You cannot just rely on the low goal, at the CMP level you will be out scored on most occasions on Saturday, however you will gain that ranking point in quals which is always wanted. You have to put some boulders in the upper chains. This is going to be a neat addition to offensive and defensive strategy at CMP.
"There is no luck. It is only when preparation meets opportunity."
Unread 20-04-2016, 10:12
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
I think you made a typo...
One alliance scores 10 boulders all in the low goal in elims this = 20 points.
