Go to Post Push the envelope a little, but not too much. There's a difference between being on the cutting edge and being on the bleeding edge. - cadandcookies [more]
  #76   Spotlight this post!
Unread 20-04-2016, 11:50
Louisiana Jones's Avatar
Louisiana Jones Louisiana Jones is offline
Jason Jones
AKA: Jason Jones
FRC #1806 (S.W.A.T.)
Louisiana Jones will become famous soon enoughLouisiana Jones will become famous soon enough
Re: If YOU were the GDC...
Originally Posted by Edxu View Post
As it stands right now, defense as intended in the courtyard is effectively useless due to the multitude of teams with protected shots, and defense has all but entirely moved to the neutral zone.
While many teams shots might not be blockable, those tall opaque robots might happen to block many teams vision tracking systems. Most of the systems are mounted down low, so maybe courtyard defenders won't be entirely useless?
  #77   Spotlight this post!
Unread 20-04-2016, 15:16
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
I mean you're technically right, but if your tall opaque robot was previously a short, defense-crossing robot and you cheesecaked on a wall, you might run the issue of being called for purposely obstructing their vision from R9C.
IIRC, most refs will tend to favor the offensive robot in those calls, and your alliance risks failing inspection if the RI believes that your blocker exists for more than boulder blocking.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
  #78   Spotlight this post!
Unread 20-04-2016, 15:53
foote stepped in
AKA: E. Foote
FRC #0868
From the Q&A and related discussion, my understanding was that if your blocker exists for blocking shots, the cheesecaked wall would be perfectly legal.
If the cheesecake wall exists singularly to block/interfere with cameras, it wouldn't be allowed.
EDIT-
To get this post back on topic, If I were the GDC I would eliminate rules based on intent. Things either happen or they don't, but there's quite a bit that we didn't mean to do.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #79   Spotlight this post!
Unread 20-04-2016, 16:50
Edxu's Avatar
AKA: Edwin Xu
Your interpretation is correct, but how do you create the line between an expansive shot blocker and a wall to block cameras?
If I was to grab a 4'x4' sheet of black fabric and create a frame for it such that it widened my blocking wall for boulders, I could make the argument that its purpose is to increase blocking surface area, but the opposing alliance could claim that your ulterior motive is to mess with their camera.
2013-2016: Team 610
  #80   Spotlight this post!
Unread 20-04-2016, 18:08
Jason Jones
AKA: Jason Jones
From the Q&A
A. A device which is not specifically intended to interfere with the remote sensing capabilities of another ROBOT, but merely happens to be in the way of that ROBOT sensing a desired object, while intended for other functions(such as blocking shots), would not be a violation of R9-C.
If your camera is mounted low then you knew the possibility existed for someone to drive in front of you. Its probably better if we don't make this another intent rule, where an official has to try to figure out what your team is thinking.
  #81   Spotlight this post!
Unread 20-04-2016, 18:19
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
From the Q&A
The RI's will ask the team if they intended it to block shots, or obscure the ability of vision tracking.
If they say that it is only meant to block shots, then it will be allowed.
This happened at the NEDCMP, where a team added a blocker of Lexan, but the kept the opaque protective covering on it.
It was allowed.
But I sort of agree with you assertion that if you have a vision system mounted low, it may be blocked.
We'll see how this plays out in two weeks.
  #82   Spotlight this post!
Unread 20-04-2016, 22:41
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I see a lot of robots making contact initially inside the bumper zone and then getting wedged over/under leading to inadvertent tipping. I would change the bumper rules so teams can make taller than 5 inch bumpers as long as they have 5 inch bumpers within the bumper zone. Teams would be place the bumpers outside of the 4-12 inches as long as 5 inches is always within the zone. In other words, teams can stack 2 noodles to create a standard 5" bumpers. Maybe cap the total height at 5inches.
I would also require robots to have 5"inches of bumper within the bumper zone when 100 or so pounds of force is applied to each side of the robot. Inspectors can check this relatively easily. This would help in situations where robots tilt back and forth from change in directions and their center wheel drops, and then their bumper heights change.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
  #83   Spotlight this post!
Unread 20-04-2016, 23:13
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Get rid of the audience-selected defense. Yeah, it's fun, I know. Maybe I'm just lazy, but it's a lot of work to make sure you're cheering for the right one, and it cripples defense selection strategy. There's so many things that can be done with defense selection that are eliminated by taking away the control of slot 3.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
  #84   Spotlight this post!
Unread 21-04-2016, 00:28
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Get rid of category C defenses. Pretend the GDC never created it.
And for all events currently and in the future, the dumb white line in front of driver stations. I hate seeing DS's flying off the supporting platform from robots ramming the wall.
  #85   Spotlight this post!
Unread 21-04-2016, 01:08
Edxu's Avatar
AKA: Edwin Xu
Isn't the velcro there to STOP DS's from flying off the platforms? Or is it not effective enough?
2013-2016: Team 610
  #86   Spotlight this post!
Unread 21-04-2016, 01:11
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
If a robot runs full speed into the driver station wall? Not even close to enough.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
  #87   Spotlight this post!
Unread 21-04-2016, 01:19
EricH EricH is online now
The white line is there because back when auto was introduced, people immediately started thinking of ways to control their robots in auto. (There are threads on this, I've seen a couple of them.) So the GDC at the time put that line in. The idea is that you can reach your controls if you really need to, but the refs have a chance at seeing you do so.
And, there is NOTHING preventing you from taking actions to save your controls.
For the Category C defenses, I'd go with use different defenses. They did have other defenses on the drawing boards... Anybody want to try a rolling log or a spinning table? (One of those two was on the list, if I recall the podcast on that correctly...)
With respect to the vision/shot blocking, had a team at one event I reffed at show up with an improvised blocker: a volleyball net on a PVC frame. Great, it's see-through, they passed inspection no problem. The next match they came out and it was covered with painter's tape. That got the head ref asking questions. The tape didn't appear again after that match...
  #88   Spotlight this post!
Unread 21-04-2016, 03:05
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
There might be tweaks like the ones suggested, but the GDC got this one right. Funny after the snoozer last year.
I like that the capture has to happen with all 3 robots in place. I still would like the GDC to send out a notice in September that a game will require that ALL 3 bots will need to accomplish a task to gain significant points. That would encourage teams to work together in the preseason.
  #89   Spotlight this post!
Unread 21-04-2016, 06:26
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
I disagree. If FIRST needs to put out a disclaimer to get teams to work together, there's a culture problem that needs to be addressed. Teams helping each other should be the default.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
  #90   Spotlight this post!
Unread 21-04-2016, 06:52
DaveL DaveL is online now
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
I would like to see more motivation for teams to build shooting robots and to gain points for passing between robots.
The way to do might be to allow shooting boulders over the barriers in both directions and to have more visual targets for robots to use in auto mode. Plus larger targets would motivate more teams to build shooting robots.
Others mentioned the divider on the batter, I would go one step further and add some tint to the dividers on the barriers, to make it easier to line up and drive thru a barrier opening.
