Re: Are there any alternatives to an electric actuator?
Pic: https://www.facebook.com/LNRobotics/...09258065893970 Don't know if this is relevant to what OP is trying to do. |
It depends a lot on the specifics of the application. I will take swinging a 5 lb sword as the need, in terms of speed, weight, needs to swing both ways, swing force and several swings needed but only one at a time, and 'cheap' as far as cost.
An electric solenoid doesn't have the force, but can do everything else. Get a cr srater motor and remove the solenoid, about 10 lbs force but a throw of only an inch. A motor maybe, with a linkage to produce the swinging motion (and not driving the arm directly) - think a rotating disk with a linkage pinned near the outer diameter. A window lifter motor can go 60 RPM or more, so a swing there and back is a second. The problem here is a 'single' swing needs time for the motor to get up to speed. Pneumatics offer it all, but cost is not 'cheap', even with an off-board compressor. Linear (electrical) actuators are just too slow A motor driving a lead screw could be good. Mechanical complexity is the disadvantage here, but perhaps the best choice of all so far. |
Come to think of it...
I'm not sure you want a motor, per se. Figure out how much torque you'll need to move what you're moving, then go down to your local hobby store that deals with large R/C stuff. You're looking for a good-sized servo. (Servo motors are technically motors, but they're set up to hold a given position rather than run at a given speed--unless you're making a continuous-rotation servo run at speed.) The bonus here is that servos are rigged for linkages (say, a pivot) so you can really open up your options if you work it right. They don't rotate very fast, necessarily. And, they're relatively cheap. You'll just need a controller--the RoboRIO has servo slots, as I recall, and I know that Arduinos can handle 'em. |
Electric linear actuators might work however if you include a lever multiplier. If you apply the force near the pivot, the resulting end of the arm moves much faster. Again we aren't sure the scale, but if you actuator was attached 6 inches along a 3 foot arm, the end would travel 6 times faster and 6 times further than the actuator. Of course the limitation is 6 times less torque, but depending on the specific motor solution you may have way too much of that anyways. |
Depending on the forcespeed requirement, look at robot designs from Arial Assist (the 2014 game) - a whole lot of robots that year utilized a catapult to launch the ball, which is just an arm doing a swinging motion vertically instead of horizontally. Some were pneumatically driven, others utilized springs or surgical tubing/spear gun tubing with a motor to pull it back, and others used a motor to drive the arm directly. Even if that's faster than you want, you might get some useful ideas from those designs, all you'd need to do is slow them down!
#7
I wonder if a sketch by the OP might generate more specific ideas. Springs/Rubber Bands might be able to store enough energy for a swinging motion with smaller motors. |
#8
Admittedly, it might need to be a rather large servo of that general type, but some of the sailing ones might be powerful enough. |
