#16
Re: Cheapish CNC machine
At $25 a stepper plus say $30 bucks an amp.
That is about $150 to get controls alone unless you salvaged. I assume $500 is the machine itself? Prusa 3D printers are in this price range now at not nearly that build quality. |
#18
Thanks, I'm planning on writing a build log about it soon. The only thing that is custom on the machine is the spindle but that could be made on a drill press if need be. To keep the costs down I imported almost all of the parts directly from China
#19
What kind of accuracy and repeatability are you getting? |
#20
, I wouldn't settle for anything less. I haven't tuned the machine yet but the tolerances are higher than my chinese digital caliper can read (perfectly acceptable for FRC use) |
#22
Our team will do anything, to have access to something like this. There have been several situation this past season where a cnc machine would have been a god send.
#24
I have a cheap Chinese CNC router from Ebay at home. The electronics were done poorly and we had to re-work the stepper controllers, but mechanically, it is a fairly good machine. We use these router bits for aluminum and have had great results. They cut much cleaner and faster than a standard end mill, but still are not fast.
#25
Kind of suspect your CNC shield is a RAMPS 1.4? |
#26
What are the differences between an x-carve and a shapeko3? The shapeko 3 website shows videos of it milling into aluminum pretty easily....
#28
Accuracy, repeatability and grade of aluminium. I have no doubt you can force aluminum into a drill press with an X/Y table as well and it will cut. Eventually the drill press will fail from that but I know folks do it. Some even toss the drill presses and replace them because the presses are -that- cheap they are literally disposable. Last edited by techhelpbb : 20-04-2016 at 21:47. |
#29
We actually used the X-Carve to machine our practice robot this year and it did a pretty good job. We put a LOT of work into learning how to properly use CAM software and feeds/speeds but eventually we found the sweet spot for both 5052 and 6061 with our setup. We machined our bellypan, chassis rails, superstructure gussets, and shooter components from components .050" to .1875" thick. You definitely will have better luck with with an actual CNC mill, but for a router, the X-Carve (with mods) can take you just about as far as you are willing to put into it.
#30
