Re: Cheapish CNC machine
I have a cheap Chinese CNC router from Ebay at home. The electronics were done poorly and we had to re-work the stepper controllers, but mechanically, it is a fairly good machine. We use these router bits for aluminum and have had great results. They cut much cleaner and faster than a standard end mill, but still are not fast.
What are the differences between an x-carve and a shapeko3? The shapeko 3 website shows videos of it milling into aluminum pretty easily....
Accuracy, repeatability and grade of aluminium. I have no doubt you can force aluminum into a drill press with an X/Y table as well and it will cut. Eventually the drill press will fail from that but I know folks do it. Some even toss the drill presses and replace them because the presses are -that- cheap they are literally disposable. Last edited by techhelpbb : 20-04-2016 at 21:47. |
We actually used the X-Carve to machine our practice robot this year and it did a pretty good job. We put a LOT of work into learning how to properly use CAM software and feeds/speeds but eventually we found the sweet spot for both 5052 and 6061 with our setup. We machined our bellypan, chassis rails, superstructure gussets, and shooter components from components .050" to .1875" thick. You definitely will have better luck with with an actual CNC mill, but for a router, the X-Carve (with mods) can take you just about as far as you are willing to put into it.
If you make your own brackets or sink a hole into the wasteboard, you can get a theoretical maximum of about 5-6". There's guides on youtube; it is opensource after all. |
#8
These work wonders Carbide 3 flute with a special coating, $15-12 for the 1/8 and around $20-25 for the 1/4.
The seller, drillman, has great deals on some high quality bits; I recommend you read some of the FAQs about the Destiny line as it has a unique coating that more or less saves you from getting the bit stuck in 5052 and gooey materials. |
#10
GOFIRST is currently looking at getting a Routakit CNC router. Even with some upgrades, it comes out around $2000 if you get a standard version. Specifically we're looking at getting the SD with the SDX upgrade kit and improved spindle. It looks like a pretty solid machine, and they have a pretty cool forum post documenting the process of designing their first one (I think it's somewhere in the Shapeoko forums but can't find it right now). They're also super nice and responsive-- I've emailed them a few times with questions and am really hoping it makes sense for us to get one.
#11
Take a look at the construction and specs:
X-Carve: DeWalt DW611 Router (or choice) 140 oz-in NEMA 23 steppers (or 60 oz-in NEMA 17 steppers) Arduino with g-shield Lead Screw or Threaded Rod z-axis Max 31" x 31" x 2.55" work area 0.075-0.13 mm resolution GT2 belts (pitch not specified, assumed 2mm) ~$1400 fully loaded Shapeoko 3: Router not included (DW611 recommended) 120 oz-in NEMA 23 steppers Proprietary electronics Belt-driven Z-axis Max 16" x 16" x 3" work area No apparent claims on resolution/accuracy GT2 2mm pitch belts $999 Routakit SD (no upgrades): 600W spindle 175 oz-in NEMA 23 steppers PlanetCNC controller (which one not specified on page) Ball Screw z-axis Max 59.1" x 59.1" x 4" work area (30" x 30" x 4" default) Repeatability 0.025 - 0.05 mm Accuracy +/- 0.127 mm 9mm wide, 3mm pitch GT2 belting $1799 Routakit SDX (what GOFIRST is looking at) 1500W spindle 30" x 15" x 4" work area SDX upgrade for greater rigidity $2179 We're looking at it for somewhat similar uses to what I expect a team would want-- the most intense thing we expect to cut is maybe occasional 1/4" aluminum, but mostly 1/8" or polycarbonate. I haven't heard good things about cutting aluminum on an X-carve, and the Shapeoko doesn't have the work area we want. It might not be the right option for someone else, but it seems to be the closest to right for us, given our budget, without spending a lot of time designing our own (and, to be honest, we're probably going to mod the crap out of anything we get anyways, because we're all tinkerers). |
#13
If 750W is about 1HP. A 1500W spindle is 2HP. Now the important questions about the spindle are: 1. At what RPM is maximum mechanical power output? Does the motor driver effect that? 2. Is that RPM a good match for the feed rates these NEMA23 steppers can deliver and honestly the answer in all 3 cases is likely no. So the quality of cut and the tool life will diminish. Though obviously the results can always be good enough and someone could always get more tools. Last edited by techhelpbb : 21-04-2016 at 07:30. |
#14
There's also a major difference between using a standard woodworking router or an industrial spindle. The ShopBot FAQ has a good explanation of this. |
#15
I purchased a bare bones X-Carve 500mm last December for the team. Several of the parts and electronics were purchased separately. Total cost to put the machine in service about 690.00$. A stock X-carve will cut 6061-T6. However, it is not acceptable from a precision and speed perspective. The main problem is x and z axis torsional stiffness. I modded the x axis maker slide with a 40 x 4 500 mm Al plate to tie the 2 maker slides together. The torsional problem did not go away until I replaced the Delrin wheels with metal wheels. The machine can now cut with reasonable speed and precision, but not like a 12000$ commercial unit. It has been a great addition to the team and made many parts on our 2 robots. I should mention that about 1/2 the parts cut were 7075. With all the mods 7075 is not a problem. Stock it is. Looking back I could have built a better machine for the same money. However designing a machine from scratch takes allot of knowledge that I did not have last December. Be careful of the eBay Chinese stuff. Some of it is good and some terrible. Yes, a sub 1000$ router can be a great addition to a team. One thing I should note is that 1 requirement for our router was that it had to be portable. We do not have room for a permanent set up. The 500mm x-carve fits this requirement.
