Go to Post Force yourself now, today, to learn one new thing each day. When you lay down on your fluffy pillow at night, before you say your prayers, ask yourself if you have learned anything new. If the answer is "NO" then you better get up and find something. - Al Skierkiewicz [more]
Unread 20-04-2016, 20:38
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: Cheapish CNC machine
Originally Posted by mman1506 View Post
I built this machine for about 500$ USD (I haven't built the enclosure yet so it's a bit of mess). It cuts aluminium better than X-Carve or Shapeoko IMO, I can fairly easily do 1/16 DOC at 15 IPM with a 1/8 Carbide single flute end mill. I cut this sprocket on it in about 15 minutes. It's definitely not something I'd recommend to someone new to CNC machining but a practical machine for aluminium can be made for well under the price of an X-Carve.
I would love it, if you are capable of sharing the plans for this. The 500 dollar price range is insane
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 20-04-2016, 20:53
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
At $25 a stepper plus say $30 bucks an amp.
That is about $150 to get controls alone unless you salvaged.
I assume $500 is the machine itself?
Prusa 3D printers are in this price range now at not nearly that build quality.
Unread 20-04-2016, 20:55
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Originally Posted by asid61 View Post
That looks really good! Any chance we can get some plans?
I've seen Shapeoko 3's out-of-the-box cut aluminum, albeit slowly.
Thanks, I'm planning on writing a build log about it soon. The only thing that is custom on the machine is the spindle but that could be made on a drill press if need be. To keep the costs down I imported almost all of the parts directly from China
2016: FRC 865 Mentor
Unread 20-04-2016, 21:01
techhelpbb's Avatar
ACME screws or standard threaded rod?
What kind of accuracy and repeatability are you getting?
Unread 20-04-2016, 21:03
mman1506's Avatar
no team (WARP7)
I bought the steppers for $3.50 each and the drivers + CNC shield+ Arduino was another 20$. The frame was about 280$ including ball screws and linear rails. Shipping accounted for about 1/4 of the cost of the machine.
Unread 20-04-2016, 21:06
mman1506's Avatar
no team (WARP7)
Ball Screws , I wouldn't settle for anything less. I haven't tuned the machine yet but the tolerances are higher than my chinese digital caliper can read (perfectly acceptable for FRC use)
Unread 20-04-2016, 21:07
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
You sir, are a master
Unread 20-04-2016, 21:08
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Our team will do anything, to have access to something like this. There have been several situation this past season where a cnc machine would have been a god send.
Unread 20-04-2016, 21:10
echin's Avatar
echin echin is offline
AKA: Eric Chin
FRC #3467 (Windham Windup)
echin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the rough
I have a cheap Chinese CNC router from Ebay at home. The electronics were done poorly and we had to re-work the stepper controllers, but mechanically, it is a fairly good machine. We use these router bits for aluminum and have had great results. They cut much cleaner and faster than a standard end mill, but still are not fast.
FRC 3467 Chief Technology Officer (Co-Captain)
FTC 10251 Design Mentor
Unread 20-04-2016, 21:12
techhelpbb's Avatar
Very nice! Will look forward to the build log. I do not know of any sources for good multi-turn ball screws and ball anti-backlash nuts in a price range like that. Usually they resort to threaded rod or nylon blocks heated then pressed and sooner or later that bites you from wear.
Kind of suspect your CNC shield is a RAMPS 1.4?
Unread 20-04-2016, 21:14
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Thanks for the advice, will keep it in mind if and when we hopefully get a cnc router
Unread 20-04-2016, 21:24
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
What are the differences between an x-carve and a shapeko3? The shapeko 3 website shows videos of it milling into aluminum pretty easily....
Unread 20-04-2016, 21:34
techhelpbb's Avatar
A couple of things to note video is terrible at showing:
Accuracy, repeatability and grade of aluminium.
I have no doubt you can force aluminum into a drill press with an X/Y table as well and it will cut. Eventually the drill press will fail from that but I know folks do it. Some even toss the drill presses and replace them because the presses are -that- cheap they are literally disposable.
Unread 20-04-2016, 21:39
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud of
We actually used the X-Carve to machine our practice robot this year and it did a pretty good job. We put a LOT of work into learning how to properly use CAM software and feeds/speeds but eventually we found the sweet spot for both 5052 and 6061 with our setup. We machined our bellypan, chassis rails, superstructure gussets, and shooter components from components .050" to .1875" thick. You definitely will have better luck with with an actual CNC mill, but for a router, the X-Carve (with mods) can take you just about as far as you are willing to put into it.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 20-04-2016, 21:41
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
What is the thickest block of aluminum do you think it can work with? (just wondering about the height of the z axis)
