Go to Post Nonetheless, I would welcome it, as long as [The President] didn't restrict the number of discs that a Robot could hold. Oops, wait, too late, the GDC already did that. :-) - MooreteP [more]
  #31   Spotlight this post!
Unread 20-04-2016, 21:53
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Re: Cheapish CNC machine
Originally Posted by dirtbikerxz View Post
What is the thickest block of aluminum do you think it can work with? (just wondering about the height of the z axis)
You can get about 2.25" of max height if you:
  • Use the stock wasteboard
  • Use the stock z-height plates
If you make your own brackets or sink a hole into the wasteboard, you can get a theoretical maximum of about 5-6". There's guides on youtube; it is opensource after all.
Cortechs Robotics 2014-Present
Mechanical, CAD
  #32   Spotlight this post!
Unread 20-04-2016, 22:18
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Cool. What bits did you guys use?
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
  #33   Spotlight this post!
Unread 20-04-2016, 22:21
jkelleyrtp's Avatar
AKA: Jon Kelley
These work wonders Carbide 3 flute with a special coating, $15-12 for the 1/8 and around $20-25 for the 1/4.
The seller, drillman, has great deals on some high quality bits; I recommend you read some of the FAQs about the Destiny line as it has a unique coating that more or less saves you from getting the bit stuck in 5052 and gooey materials.
Mechanical, CAD
  #34   Spotlight this post!
Unread 20-04-2016, 22:31
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
GOFIRST is currently looking at getting a Routakit CNC router. Even with some upgrades, it comes out around $2000 if you get a standard version. Specifically we're looking at getting the SD with the SDX upgrade kit and improved spindle. It looks like a pretty solid machine, and they have a pretty cool forum post documenting the process of designing their first one (I think it's somewhere in the Shapeoko forums but can't find it right now). They're also super nice and responsive-- I've emailed them a few times with questions and am really hoping it makes sense for us to get one.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #35   Spotlight this post!
Unread 20-04-2016, 23:31
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
why is routakit better than xcarver or shapeko3?
  #36   Spotlight this post!
Unread 21-04-2016, 00:04
JohnFogarty's Avatar
AKA: @doctorfogarty
We actually used the X-Carve to machine our practice robot this year and it did a pretty good job. We put a LOT of work into learning how to properly use CAM software and feeds/speeds but eventually we found the sweet spot for both 5052 and 6061 with our setup. We machined our bellypan, chassis rails, superstructure gussets, and shooter components from components .050" to .1875" thick. You definitely will have better luck with with an actual CNC mill, but for a router, the X-Carve (with mods) can take you just about as far as you are willing to put into it.
I'd be interested to hear what settings, speeds/feeds you used. I really couldn't get the one I had access to for a short while to do that much with with aluminum. I used Autodesk 360 to do my CAM and my guess is that I had some depth/plunge and speed/feed rates wrong.
John Fogarty
  #37   Spotlight this post!
Unread 21-04-2016, 00:33
AKA: Nick Aarestad
Take a look at the construction and specs:
X-Carve:
DeWalt DW611 Router (or choice)
140 oz-in NEMA 23 steppers (or 60 oz-in NEMA 17 steppers)
Arduino with g-shield
Lead Screw or Threaded Rod z-axis
Max 31" x 31" x 2.55" work area
0.075-0.13 mm resolution
GT2 belts (pitch not specified, assumed 2mm)
~$1400 fully loaded
Shapeoko 3:
Router not included (DW611 recommended)
120 oz-in NEMA 23 steppers
Proprietary electronics
Belt-driven Z-axis
Max 16" x 16" x 3" work area
No apparent claims on resolution/accuracy
GT2 2mm pitch belts
$999
Routakit SD (no upgrades):
600W spindle
175 oz-in NEMA 23 steppers
PlanetCNC controller (which one not specified on page)
Ball Screw z-axis
Max 59.1" x 59.1" x 4" work area (30" x 30" x 4" default)
Repeatability 0.025 - 0.05 mm
Accuracy +/- 0.127 mm
9mm wide, 3mm pitch GT2 belting
$1799
Routakit SDX (what GOFIRST is looking at)
1500W spindle
30" x 15" x 4" work area
SDX upgrade for greater rigidity
$2179
We're looking at it for somewhat similar uses to what I expect a team would want-- the most intense thing we expect to cut is maybe occasional 1/4" aluminum, but mostly 1/8" or polycarbonate. I haven't heard good things about cutting aluminum on an X-carve, and the Shapeoko doesn't have the work area we want. It might not be the right option for someone else, but it seems to be the closest to right for us, given our budget, without spending a lot of time designing our own (and, to be honest, we're probably going to mod the crap out of anything we get anyways, because we're all tinkerers).
tumblr | twitter
VEXU UMN (2015-??)
  #38   Spotlight this post!
Unread 21-04-2016, 07:10
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
140 oz-in NEMA 23 steppers (or 60 oz-in NEMA 17 steppers)...
120 oz-in NEMA 23 steppers...
Course you might not be able actually get those mechanical results without electronics that insure at full step enough power is supplied. Once you microstep all bets are off.
If 750W is about 1HP.
A 1500W spindle is 2HP.
Now the important questions about the spindle are:
1. At what RPM is maximum mechanical power output? Does the motor driver effect that?
2. Is that RPM a good match for the feed rates these NEMA23 steppers can deliver and honestly the answer in all 3 cases is likely no.
So the quality of cut and the tool life will diminish. Though obviously the results can always be good enough and someone could always get more tools.
  #39   Spotlight this post!
Unread 21-04-2016, 07:49
Gdeaver Gdeaver is offline
FRC #1640
I purchased a bare bones X-Carve 500mm last December for the team. Several of the parts and electronics were purchased separately. Total cost to put the machine in service about 690.00$. A stock X-carve will cut 6061-T6. However, it is not acceptable from a precision and speed perspective. The main problem is x and z axis torsional stiffness. I modded the x axis maker slide with a 40 x 4 500 mm Al plate to tie the 2 maker slides together. The torsional problem did not go away until I replaced the Delrin wheels with metal wheels. The machine can now cut with reasonable speed and precision, but not like a 12000$ commercial unit. It has been a great addition to the team and made many parts on our 2 robots. I should mention that about 1/2 the parts cut were 7075. With all the mods 7075 is not a problem. Stock it is. Looking back I could have built a better machine for the same money. However designing a machine from scratch takes allot of knowledge that I did not have last December. Be careful of the eBay Chinese stuff. Some of it is good and some terrible. Yes, a sub 1000$ router can be a great addition to a team. One thing I should note is that 1 requirement for our router was that it had to be portable. We do not have room for a permanent set up. The 500mm x-carve fits this requirement.
  #40   Spotlight this post!
Unread 21-04-2016, 14:42
AKA: @doctorfogarty
Has anyone worked with a router from Probotix? They seem to be significantly more rigid than most. They additionally use screw drives instead of belts.
http://www.probotix.com/ASTEROID-CNC-ROUTER
John Fogarty
  #41   Spotlight this post!
Unread 21-04-2016, 15:05
techhelpbb's Avatar
Delrin anti-backlash nuts will wear faster than ball nuts or ACME spring nuts.
Not an issue, unless you don't check your run-out till you start ruining work pieces.
  #42   Spotlight this post!
Unread 21-04-2016, 15:13
AKA: Nick Aarestad
Another key aspect I failed to mention was the frame construction, which impacts pretty much everything. Routers are a complicated thing.
There's also a major difference between using a standard woodworking router or an industrial spindle. The ShopBot FAQ has a good explanation of this.
tumblr | twitter
VEXU UMN (2015-??)
  #43   Spotlight this post!
Unread 21-04-2016, 18:50
AKA: @doctorfogarty
Yeah, the description of the machine says just that. I figure I could replace them with a better nut.
John Fogarty
  #44   Spotlight this post!
Unread 21-04-2016, 19:42
walterev walterev is offline
FRC #1758
walterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to all
Take a look at what Brandon Satterfield is doing at http://www.smw3d.com. I built an OX using his kit of parts and the quality is outstanding. He also has some ther devices that are more comfortable with aluminum.
Plus, he supports FIRST teams with a discount.
  #45   Spotlight this post!
Unread 21-04-2016, 19:53
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We've had pretty good experiences with our X-Carve, as others have said it's great for wood and polycarbonate, but you have to take it slow with aluminum (and use cutting fluid).
Really it all depends on what you want to build. In our case we built our chassis out of 3/8" polycarbonate so using it to cut our chassis side panels is no problem, and the tolerances are more than enough if you're building a chain drive; however when we cut some custom 1/8" aluminum gearbox mounting plates for our 3-CIM Ball shifters, we had to intentionally undersize the holes and then finish them on our Bridgeport CNCs.
Basically our X-Carve is pretty good at positioning accurately, but not great at making round pockets consistently. If all you were doing was drilling straight holes and not doing any pockets, you could likely do it all day long and not have any issues with accuracy.
I don't think I would try to build an entire robot out of aluminum using an X-Carve, but using it for mostly polycarbonate parts with only a few, small aluminum pieces is certainly doable.
One thing to note for these machines is that you either have to babysit them with a vacuum or construct some sort of dust collector for it, because even the slightest bit of material flying off the part can get lodged between the tracks and the wheels and throw off the positioning of the entire unit, ruining the part. If you wanted to get really creative, adding a closed-loop control system to it would also solve the problem, and improve accuracy.
