Go to Post Tolerance, forgiveness, humor, and lessons learned are tools we can find here. - JaneYoung [more]
Unread 21-04-2016, 07:29
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
2016 IRI Rule Change Suggestions
Each year, we look at what official rules might need to be adjusted for IRI.
We have the benefit of seeing how the game is played, and we can adjust the level of difficulty (when needed) to match the level of play we see at IRI.
Gneral guidelines we use are that we won't make changes that are a major impact to designs, and we try to limit changes so that teams don't feel compelled to spend all of June and July working on their robot to meet some new challenge. We are also have to consider changes that impact FMS, automated systems, and referees.
As a note, we were already discussing the Tower Strength change to 10. We will see how that plays out at CHP.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 21-04-2016, 08:04
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: 2016 IRI Rule Change Suggestions
Change G28 so that robots can continue playing defense in the courtyard until the end of the match. They must leave robots on the batter alone, but before that robot gets to the batter, they're fair game.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 21-04-2016, 08:11
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
Originally Posted by Edxu View Post
I think that I would remove the limitation on robot height while in your own courtyard. As it stands right now, defense as intended in the courtyard is effectively useless due to the multitude of teams with protected shots, and defense has all but entirely moved to the neutral zone.
Thematically, there's no reason why a castle's defenders would need leave the defended walls to sally out to meet the attacking force short of being sieged.
This gives teams the ability to play meaningful defense in their own courtyard, while providing another design challenge in being forced to be able to shoot at all 3 goals.
This could make the game more competitive in the way that you possibly eliminate shooting from the same spot every time. Agreed in the way that it could force teams to use more goals than just the center one.
2016 Greater Pittsburgh Regional Winner (With 5406 and 1559) | Finger Lakes Regional Semi-finalist
2015 Greater Pittsburgh Regional Quarter-finalist | Finger Lakes Regional Semi-finalist
Unread 21-04-2016, 08:14
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
As the season continues, Breaching seems to be less valued, as it happens relatively quickly with a competent alliance. Something that may add an additional level of difficulty would be to require all 5 defenses to be breached to get the rank point/extra points in teleop. I don't know if that messes up the FMS, but from a referee standpoint, it shouldn't be any more work.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
An Outlier An Outlier is offline
AKA: Julian Bernard
FRC #5687 (The Outliers)
Rookie Year: 2015
An Outlier is an unknown quantity at this point
Change the wording so that Robots shooting from the Outer Works are no longer protected.
This would help with the easy-to-capture towers problem, because defense could actually do something!
Unread 21-04-2016, 08:56
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
I would make the sally port and drawbridge transparent. My preference would be to eliminate the portcullis and drawbridge completely, but that might be too drastic a rule change.
Some language to eliminate the transferring-balls-without-completely-crossing-a-defense penalties while still preventing the existence of 'defense-straddling bots' would be nice.
Some language to not penalize robots that inadvertently push a second boulder over a defense when crossing when the second boulder previously started in a defense would be nice.
I would also investigate incorporating a static or non-team-selected defense lineup to help with the space constraints (and matches would go very quickly without having to change all the defenses all the time), but I haven't done any analysis on the impact of this yet.
Add a ref in each human player station watching ball counts
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 21-04-2016, 09:01
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Get rid of audience defense selection.
Unread 21-04-2016, 09:03
natejo99's Avatar
natejo99 natejo99 is offline
Captain/Human Player
AKA: Nate Johansen
FRC #0074 (Team C.H.A.O.S.)
natejo99 is on a distinguished road
I agree with this. There has to be some better way to go about selecting the defense in slot 3.
2013-Present - Student, FRC 74
2014 FRC Champions - 254, 469, 2848, 74
2014 FRC MSC Finalists - 1718, 67, 74
2016 Traverse City District Winners - 3688, 74, 6128
2016 Tesla Quarterfinalists - 74, 2054, 4468, 3238
Thanks to our 2016 Alliance Partners:
4580, 71, 2405, 3572, 3688, 6128, 5505, 2054, 4468, 3238
Unread 21-04-2016, 09:05
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
To modify the rules to support this, I'd recommend this change:
Originally Posted by G39 IS
ROBOTS are prohibited from launching BOULDERS unless they are in contact with the opponent’s
TOWER or carpet in the opponent’s COURTYARD, and not in contact with any other carpet.
Originally Posted by G39 Revised
ROBOTS are prohibited from launching BOULDERS unless they are fully contained in the opponent’s
TOWER or carpet in the opponent’s COURTYARD.
Essentially, this removes the "safe shooting zone" of the defenses, but does not eliminate safe passage across the defenses.
Unread 21-04-2016, 09:06
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Randomly select the "audience" selection, but still have the suspense/cheer for "X", now "Y".
Make driving over a second boulder like pinning, 5 second count, then get smacked with a penalty.
Unread 21-04-2016, 09:14
foote stepped in
AKA: E. Foote
FRC #0868
The low bar can only be weakened once the other 4 defenses are damaged.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 21-04-2016, 09:19
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Robots can break the midline during autonomous, but only for a new boulder zone. Put the boulders in their own 10" "zone" where you can interact with the entirety of the ball. Itll make for some interesting auto modes.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 21-04-2016, 09:25
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Breaching and captures shouldn't be automatic, as they are slowly turning into. Changing it to 10 boulders (or higher?) should help with captures... I would also, if possible, change the requirements for damaging a defense to 3 crossings instead of two.
2016: Lake Superior WFFA
Unread 21-04-2016, 09:26
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
Remove the limitation on robots crossing Neutral Zone plane during autonomous. This encourages teams to develop more complicated autonomous programs that reflect the level of competition that should be at IRI.
Remove the height limitation of 4'6 in your own courtyard. This makes actual courtyard defense viable, and gives cheesecaking options.
If a boulder is in the way of a robot's defense crossing (eg in the low bar), don't penalize them for pushing it through. This eliminates those awkward situations where you have to outtake your ball and take the defense ball because of a weird case in the rules.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
Unread 21-04-2016, 09:31
Drakxii Drakxii is offline
FRC #4131 (Iron Patriots)
Drakxii is just really niceDrakxii is just really niceDrakxii is just really niceDrakxii is just really niceDrakxii is just really nice
Let the alliance pick all of their defenses. No audience selection, no categories, and the low bar does not have to be in slot 1 (but has to be on the field).
Michael D.
Favorite game: Aerial Assist
Least Favorite: Recycle Rush
Pantherbots Mentor - #2582 Lufkin, TX
* Lone Star Regional 2016, 2015 - 3rd place (Semifinals), 2014 - Quarterfinals, 2013 - Quarterfinals (Judges Award)
Iron Patriots Mentor - #4131 Renton, WA
PNW Ranking: 2016 - 18
* Auburn Mountain View District Event 2016 - Semifinals (EE Award)
* Auburn District Event 2016 - Finalists (ID Award)
* PNW Champs 2016 - Quarterfinals
* World Champs 2016 - Carson
