Go to Post You don't need to be on a team to be involved with FIRST. - Koko Ed [more]
  #31   Spotlight this post!
Unread 21-04-2016, 11:00
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
Re: 2016 IRI Rule Change Suggestions
Add 2 more "refs" to focus on the outerworks, and reverse the hinge side of the sally port. These two new refs would not need to call any fouls and would only need to know the wave off and what counts as a crossing.
As for actual adjustments to the game, I'll leave that up to everyone else
Peachtree Regional Volunteer since 2003
  #32   Spotlight this post!
Unread 21-04-2016, 11:04
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Leave all of the defenses in the same place for each round of matches so we can play more matches and make field reset easier. Don't change them until every team has played their first match, then until every team has played their second match, etc...
  #33   Spotlight this post!
Unread 21-04-2016, 11:11
SoccerTaco's Avatar
SoccerTaco SoccerTaco is offline
Mentor, Volunteer
AKA: Steve Parham
FRC #3824 (roHAWKtics)
SoccerTaco will become famous soon enough
Originally Posted by An Outlier View Post
Change the wording so that Robots shooting from the Outer Works are no longer protected.
The protected zone around the outer works was not a loophole in the rules, but an obvious and almost certainly intentional aspect of the game. Yet, relatively few teams took advantage of it. I don't think teams should be penalized for having made good design choices to take advantage of the obvious protected zone.
  #34   Spotlight this post!
Unread 21-04-2016, 11:15
chandrew's Avatar
chandrew chandrew is offline
Strategy Sun Tzu
AKA: Andrew Chan
FRC #1410 (The Kraken)
Team Role: Tactician
chandrew is an unknown quantity at this point
Add extra points for multi climbs/a triple climb bonus. Maybe make the rough terrain blocks a bit taller so that there's a reason to select it. Possibly add weight/take off the constant force springs on the portcullis?
  #35   Spotlight this post!
Unread 21-04-2016, 11:17
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Replace the 5th defense with another Low Bar to encourage more two ball autonomous routines.
Or allow teams to replace whatever defense gets put in position 5 with the Low Bar but don't only give it points for the first crossing as the "penalty" for putting it in.
1058 PVC Pirates 2016 - xxxx
  #36   Spotlight this post!
Unread 21-04-2016, 11:35
Matthew1998 Matthew1998 is offline
FRC #4967
Matthew1998 is an unknown quantity at this point
Return any ball that flies out of the field to the SPY. They can do what we they want with the ball, except score it.
  #37   Spotlight this post!
Unread 21-04-2016, 11:41
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
If the goal is to increase scores, have 3 balls start touching the castle wall, but not in the secret passage, on each side placed by the alliance in that tower.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
  #38   Spotlight this post!
Unread 21-04-2016, 11:52
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Does that include nailing a defending robot?
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #39   Spotlight this post!
Unread 21-04-2016, 11:56
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by Chris is me View Post
Replace the drawbridge and sally port with clear polycarbonate.
I know this will cost money, but it's worth it. If a team I'm with ends up competing, I would honestly donate to a Fix The IRI Drawbridge Fund to help make this happen. The drawbridge is just such a crummy field object and it really ruins the flow of the game when it is out there. It would just make a subset of IRI matches worse to watch and play in.
I'd also donate to this fund. The drawbridge seems to be much harder than the sally port for many teams (since you can't just spin around/wiggle to break contact), but it's not getting much use because of how much of a hinderence it is to drivers. It's almost like there's only 8 defenses instead of 9 because of how little it's used. There's something to be said for tradeoffs, but I think it would still a challenging defense to cross even if the door was clear. The #damaged/#opportunities success rate in the quals at the DCMPs was low, which is partly due to the abysmally low denominator, but also because it's difficult.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #40   Spotlight this post!
Unread 21-04-2016, 12:02
P.J.'s Avatar
P.J. P.J. is online now
Proud Member of the Herd
P.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond repute
For those keeping score at home (because I love numbers) the Drawbridge was the least selected defense in Qualifications, being chosen 27.67% of the time. However the Portcullis (28.71%) and Rough Terrain (29.29%) weren't chosen with much more frequency.
In Playoffs, the Drawbridge was actually chosen with MORE frequency (28.30%) than either the Portcullis (28.17%) or Rough Terrain (20.87%)
Your mileage may vary based on region, week of competition, district vs regional vs DCMP, etc.
P.J. Lewalski
Team 910-The Foley Freeze -- Student 2007-2010, Mentor 2012-2016
FRC Referee 2011-Present
Referee at 29 Regular Season Events, 3 World Championships, 24 Off Season Events, and Counting
  #41   Spotlight this post!
Unread 21-04-2016, 12:38
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
At MAR CMP, according to TBA, the drawbridge went 0/34 in quals and 0/13 in playoffs. We are one of the teams guilty of putting the Drawbridge in 4, since in that spot it is worse for the opponent than for you in many cases.
Looking at NE, they had the drawbridge go 0/9 in quals and 0/17 in playoffs.
Unless you are one of the few with a very good dedicated drawbridge mechanism, at the highest levels, it's not worth your time versus scoring more boulders and just lowers everybody's scores.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
  #42   Spotlight this post!
Unread 21-04-2016, 12:45
AKA: Kara Bakowski
I did see that too. For category A at DCMPs (which I'm using because IMO they'd be more similar in competitiveness to IRI than a regional), the portcullis and cheval seem to have similar success rates, so it makes sense to choose the one that doesn't impede vision at all. Looking at some week 6 districts and regionals, if the success rate isn't the same, the portcullis tends to have a slightly higher success rate.
For category D, I'm guessing that's because the rough terrain is incredibly easy compared to the rock wall; it gives your opponents a fast way in and out of the courtyard. I'm surprised the rough terrain wasn't used less. I'd actually like to see the rough terrain modified somehow to increase its difficulty for IRI and put it more on the same level as the rock wall, but that might be changing the game too much.
Kara Bakowski
WMWBS '10 '11
  #43   Spotlight this post!
Unread 21-04-2016, 12:52
P.J.'s Avatar
I totally agree with your assessment. Additionally, Rough Terrain use dropped to only about 24% in both Weeks 6 and 7 (and even lower to 21 and 19% in Playoffs), and I wouldn't be surprised if it drops even lower at Champs.
The question becomes what could be done to increase the difficulty of the Rough Terrain without changing the game too much?
P.J. Lewalski
  #44   Spotlight this post!
Unread 21-04-2016, 13:01
BotDesigner's Avatar
BotDesigner BotDesigner is online now
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Originally Posted by CJ_Elliott View Post
Human players able to throw balls for a score in the last 20 seconds
+1
  #45   Spotlight this post!
Unread 21-04-2016, 13:05
FRC #4967
The main breaker shouldn't be that hard of a target.
