Go to Post Please stand up and be proud of who you are and what you believe in! - MattK [more]
  #35   Spotlight this post!
Unread 21-04-2016, 15:05
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Cheapish CNC machine
Originally Posted by JohnFogarty View Post
Has anyone worked with a router from Probotix? They seem to be significantly more rigid than most. They additionally use screw drives instead of belts.
http://www.probotix.com/ASTEROID-CNC-ROUTER
Delrin anti-backlash nuts will wear faster than ball nuts or ACME spring nuts.
Not an issue, unless you don't check your run-out till you start ruining work pieces.
