#31
Re: Cheapish CNC machine
If you make your own brackets or sink a hole into the wasteboard, you can get a theoretical maximum of about 5-6". There's guides on youtube; it is opensource after all. |
#32
These work wonders Carbide 3 flute with a special coating, $15-12 for the 1/8 and around $20-25 for the 1/4.
The seller, drillman, has great deals on some high quality bits; I recommend you read some of the FAQs about the Destiny line as it has a unique coating that more or less saves you from getting the bit stuck in 5052 and gooey materials. |
#34
GOFIRST is currently looking at getting a Routakit CNC router. Even with some upgrades, it comes out around $2000 if you get a standard version. Specifically we're looking at getting the SD with the SDX upgrade kit and improved spindle. It looks like a pretty solid machine, and they have a pretty cool forum post documenting the process of designing their first one (I think it's somewhere in the Shapeoko forums but can't find it right now). They're also super nice and responsive-- I've emailed them a few times with questions and am really hoping it makes sense for us to get one.
#35
#37
Take a look at the construction and specs:
X-Carve: DeWalt DW611 Router (or choice) 140 oz-in NEMA 23 steppers (or 60 oz-in NEMA 17 steppers) Arduino with g-shield Lead Screw or Threaded Rod z-axis Max 31" x 31" x 2.55" work area 0.075-0.13 mm resolution GT2 belts (pitch not specified, assumed 2mm) ~$1400 fully loaded Shapeoko 3: Router not included (DW611 recommended) 120 oz-in NEMA 23 steppers Proprietary electronics Belt-driven Z-axis Max 16" x 16" x 3" work area No apparent claims on resolution/accuracy GT2 2mm pitch belts $999 Routakit SD (no upgrades): 600W spindle 175 oz-in NEMA 23 steppers PlanetCNC controller (which one not specified on page) Ball Screw z-axis Max 59.1" x 59.1" x 4" work area (30" x 30" x 4" default) Repeatability 0.025 - 0.05 mm Accuracy +/- 0.127 mm 9mm wide, 3mm pitch GT2 belting $1799 Routakit SDX (what GOFIRST is looking at) 1500W spindle 30" x 15" x 4" work area SDX upgrade for greater rigidity $2179 We're looking at it for somewhat similar uses to what I expect a team would want-- the most intense thing we expect to cut is maybe occasional 1/4" aluminum, but mostly 1/8" or polycarbonate. I haven't heard good things about cutting aluminum on an X-carve, and the Shapeoko doesn't have the work area we want. It might not be the right option for someone else, but it seems to be the closest to right for us, given our budget, without spending a lot of time designing our own (and, to be honest, we're probably going to mod the crap out of anything we get anyways, because we're all tinkerers). |
#38
If 750W is about 1HP. A 1500W spindle is 2HP. Now the important questions about the spindle are: 1. At what RPM is maximum mechanical power output? Does the motor driver effect that? 2. Is that RPM a good match for the feed rates these NEMA23 steppers can deliver and honestly the answer in all 3 cases is likely no. So the quality of cut and the tool life will diminish. Though obviously the results can always be good enough and someone could always get more tools. Last edited by techhelpbb : 21-04-2016 at 07:30. |
#39
I purchased a bare bones X-Carve 500mm last December for the team. Several of the parts and electronics were purchased separately. Total cost to put the machine in service about 690.00$. A stock X-carve will cut 6061-T6. However, it is not acceptable from a precision and speed perspective. The main problem is x and z axis torsional stiffness. I modded the x axis maker slide with a 40 x 4 500 mm Al plate to tie the 2 maker slides together. The torsional problem did not go away until I replaced the Delrin wheels with metal wheels. The machine can now cut with reasonable speed and precision, but not like a 12000$ commercial unit. It has been a great addition to the team and made many parts on our 2 robots. I should mention that about 1/2 the parts cut were 7075. With all the mods 7075 is not a problem. Stock it is. Looking back I could have built a better machine for the same money. However designing a machine from scratch takes allot of knowledge that I did not have last December. Be careful of the eBay Chinese stuff. Some of it is good and some terrible. Yes, a sub 1000$ router can be a great addition to a team. One thing I should note is that 1 requirement for our router was that it had to be portable. We do not have room for a permanent set up. The 500mm x-carve fits this requirement.
#40
Has anyone worked with a router from Probotix? They seem to be significantly more rigid than most. They additionally use screw drives instead of belts.
http://www.probotix.com/ASTEROID-CNC-ROUTER |
#41
Not an issue, unless you don't check your run-out till you start ruining work pieces. |
#42
There's also a major difference between using a standard woodworking router or an industrial spindle. The ShopBot FAQ has a good explanation of this. |
#43
Yeah, the description of the machine says just that. I figure I could replace them with a better nut.
#44
Take a look at what Brandon Satterfield is doing at http://www.smw3d.com. I built an OX using his kit of parts and the quality is outstanding. He also has some ther devices that are more comfortable with aluminum.
Plus, he supports FIRST teams with a discount. |
#45
We've had pretty good experiences with our X-Carve, as others have said it's great for wood and polycarbonate, but you have to take it slow with aluminum (and use cutting fluid).
Really it all depends on what you want to build. In our case we built our chassis out of 3/8" polycarbonate so using it to cut our chassis side panels is no problem, and the tolerances are more than enough if you're building a chain drive; however when we cut some custom 1/8" aluminum gearbox mounting plates for our 3-CIM Ball shifters, we had to intentionally undersize the holes and then finish them on our Bridgeport CNCs. Basically our X-Carve is pretty good at positioning accurately, but not great at making round pockets consistently. If all you were doing was drilling straight holes and not doing any pockets, you could likely do it all day long and not have any issues with accuracy. I don't think I would try to build an entire robot out of aluminum using an X-Carve, but using it for mostly polycarbonate parts with only a few, small aluminum pieces is certainly doable. One thing to note for these machines is that you either have to babysit them with a vacuum or construct some sort of dust collector for it, because even the slightest bit of material flying off the part can get lodged between the tracks and the wheels and throw off the positioning of the entire unit, ruining the part. If you wanted to get really creative, adding a closed-loop control system to it would also solve the problem, and improve accuracy. |
