Go to Post SWARF is evil! - Al Skierkiewicz [more]
Unread 21-04-2016, 16:19
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Blocking 2 ball autons
Originally Posted by evanperryg View Post
I would like to introduce the "no twoball boogaloo:"
You start at the opposite side of the field from your low bar, facing towards the opposite wall. Then, drive down the center line knocking all the boulders out of position. Then, collect the last one, drive under your low bar and shoot a high goal. #einsteinstrats
Interesting idea for auton, but consider what it does to teleop.
There is no way to push a ball out of the way in auton without pushing it towards the outer works that the opponents are consistently crossing. This means that in teleop, if those balls are near those outer works they are effectively the opposing alliance's balls. At that point, for you to retrieve them you run the risk of contacting the opponent when they're in the outer works.
This is why defense bots at high levels need a great intake - they need to steal the balls from the midzone first so they don't plow them the wrong direction as they move across for defense.
GitHub
Unread 22-04-2016, 08:05
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
I'd argue having the boulders against the outer works that you're trying to cross is actually a larger obstacle to most teams than it is an aid. If the boulders are in that position care must be taken in crossing, because a poorly positioned boulder plus a hasty crossing can equal a tortuga, or at a minimum a robot getting tied up with a ball for some portion of teleop.
******Qualification: What follows below is probably not a particularly gracious or professional choice in the strategy department and I wouldn't endorse it. I'm simply observing that it could be a possibility*******
In fact, that may become a part of the strategy. If an alliance were to push the boulder into the opponents outer works while they're trying to complete a secondary auto crossing they could end up tied up for the rest of the match, eliminating significant scoring potential and making breach difficult (if a defense is obstructed by the incapacitated robot) and capture an impossibility
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
