Go to Post we were sick and tired of compromises: "speed or torque", "traction or maneuverability", etc.; bump that, we want it all. all we had to compromise was simplicity. - RogerR [more]
Unread 21-04-2016, 23:22
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
pic: 3D Print Limit Switch CFiber
Unread 21-04-2016, 23:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: 3D Print Limit Switch CFiber
Details, man. You need to attach details to a picture like this:
  • What filament?
  • What printer?
  • How does it compare mechanically to unfilled PLA/PET/ABS?
  • How easy is it to print compared to other filaments?
Unread 21-04-2016, 23:29
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
  • What filament?
  • What printer?
Also:
[*]What am I looking at, exactly?
Unread 22-04-2016, 01:48
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by asid61 View Post
Also:
Basically this.
Unread 22-04-2016, 09:01
rsegrest's Avatar
Sorry guys. Uploaded to reply to a PM from another poster. Didn't realize this would create some discussion.
What is it? We needed to mount a limit switch on a robot and so we designed this bracket. The limit switch mounted at the top of the bracket (can't really see it in the photos) and the wiring ran down the channel to the outlet at the bottom.
  • Filament - Carbon Fiber reinforced ABS
  • Printer - Makerbot Replicator 2x
  • Mechanical Comparison - Seems to be stronger and slightly lighter weight than the ABS. My printer doesn't like PLA and we have not tried the PET so can't compare to those. Trade off is that it is a more brittle in thinner prints, just doesn't have the flex that ABS has. We are planning to do some real stress testing with the machine shop instructor. He has some nifty tools we are going use to test the tensile strength compared to ABS. Will post those when we have them.
  • Print temp - I run it at about 210c.
  • Ease of print - AMAZING. Don't know about you guys that have 3D printers but about 1/2 the time it seems the room temp and humidity (thank you East Texas weather) warp my ABS jobs or they have trouble sticking to the bed. Not so with CF/ABS. Out of 20+ print jobs with it only one failed to adhere and that was a user error (ID-10-T for the techie friends out there and it was all on me ).
    Appearance of print - We like it MUCH better than ABS. It is a true matte black finish and significantly smoother to the touch even with the exact same print settings.
  • Cost - Our supplier sells it for $39.95/lb.
I think I got all the questions answered. If there are more post them and I will answer the best I can.
*Edit* Kevin - If you guys are going to TRI so is our team. I can send one of these with our engineer for you to look/see/feel what I am talking about regarding quality of the print.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 22-04-2016, 10:42
Not sure about TRI, have to talk to the Dictator-for-Life-Until-Next-Year (Lucia) about it.
What about delamination? We got a Makergear M2 in the printer raffle, and I used it last year to print string pots for the team out of ABS, but in addition to warpage, I had issues with layers just not sticking together, no matter how hot I ran things. I gave up on ABS and printed stuff from PLA this year, and recently discovered PETG. PET doesn't absorb moisture (I know!), doesn't warp, and isn't as brittle as PLA, though not quite as strong as ABS. It can be a bit messy to print since it's super gooey and stringy at temperature, but since I can't get ABS working for me....
I looked around and 3DXTech does a carbon fiber or glass fiber filled PETG that I might try if I need more strength from a part.
Unread 22-04-2016, 11:11
Jrizo's Avatar
Jrizo Jrizo is offline
FRC #4335 (Metallic Clouds)
Jrizo is an unknown quantity at this point
Smile Re: pic: 3D Print Limit Switch CFiber
Thanks for posting. This pcture just helped me solve a problem
2012 Rookie Inspiration
Dallas Regional
Unread 22-04-2016, 11:34
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
I have stayed away from carbon fiber materials on my Lulzbot Mini due to a statement on their website and this article that says carbon fiber may ruin nozzles. I'm curious if anyone here has 1st hand knowledge of these issues.
Also, how does the carbon fiber ABS part respond to an acetone vapor bath? I'm a big fan of doing this for the better layer adhesion.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 22-04-2016, 12:26
rsegrest's Avatar
WHAT?? Please tell me there is not a hidden message here
No delamination. I get it some on ABS but not a tremendous amount. When I do I re-level my bed and that - so far - has taken care of that problem.
That might just be where we ordered ours
Furellia53,
I read the same warnings. It is hard on the nozzles due to the coarser nature of CF. Makes sense if you think about it too.
If I had to guess I would say we have run about 40+ hours of CF/ABS printing and so far my nozzles have held up. They are still printing cleanly and don't appear to be having issues. I make sure to lubricate them often when I am running CF/ABS though and that may help some.
Regarding the acetone bath we haven't tried that as we have not had any delamination issues with the CF/ABS and the finish is already really nice.
*Edit*
Looks like someone has already done some tensile testing http://goo.gl/lZKCkK
~ Unknown
Last edited by rsegrest : 22-04-2016 at 12:45. Reason: Added link for tensile testing
Unread 22-04-2016, 12:50
Lucia's stepping back from Team 57 and handing it over to school management so she can focus on Champs, Lonestar, her two grandsons, and keeping her retired husband busy around the house.
Unread 22-04-2016, 13:08
zcohen's Avatar
zcohen zcohen is offline
AKA: Zac
FRC #1111 (Power Hawks)
zcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to beholdzcohen is a splendid one to behold
I've printed quite a bit with carbon fiber on my rep2 with a PLA based one. Its a bit different than the ABS but I can still give you some insights.
I agree with you, printing is beautiful. I've never ever had issues printing it. Almost seems to work better than PLA. Be warned though, buy a second nozzle. It destroys your nozzle quite quickly. We kill a nozzle per .75kg roll of filament which isnt too fun to change out. The nozzle issue isnt the end of the world, but you do need to account for having a new one otherwise your future prints will be terrible. We own four rep2s, so I only let one printer ever use that filament.
It seems stronger than the base material, but we did some stress testing on it and it actually proved to be a bit weaker. We did both compression testing and bend testing and it was a little bit weaker in both. It is considerably lighter though which is where we use it when we have a long arm and need the smallest moment possible.
Zachary Cohen
Team 1111 head mentor 2012-
Team 1712 mentor 2007-2012, 2006 alum
Technology and Engineering teacher
PLTW, STEM Magnet School
South River High School
Unread 22-04-2016, 16:31
rsegrest's Avatar
Hate that for your team but I understand completely. She is going to be one busy hopping lady!
And grandbabies are SO much more fun!!
~ Unknown
Unread 22-04-2016, 16:35
rsegrest's Avatar
[quote=zcohen;1577191] Be warned though, buy a second nozzle. It destroys your nozzle quite quickly. We kill a nozzle per .75kg roll of filament which isnt too fun to change out.[quote]
I wonder how much of a difference there is between the CF/PLA and CF/ABS?
How quickly are your nozzles deteriorating and are you lubricating them between and during prints? I have run almost 2 spools and not had a problem with my nozzles yet. I know it is a matter of time but am wondering what the contributing factors might be.
~ Unknown
Unread 23-04-2016, 20:55
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Have you built or put together a box for your Makergear M2? In my experience, using Lexan shielding or some other similar clear plastic to make a semi-insulating box really helps keep the layers together.
Unread 25-04-2016, 09:22
rsegrest's Avatar
You are quite right. The Rep 2x is enclosed and comes with a cover as well. In my room it likes the sides and front closed with the top off. If it is exceptionally cold I put the top on to keep cold drafts from getting in and messing up the job.
~ Unknown
