Go to Post the chicken crossed the road because it was a boundary. it wanted to demonstrate the spirit of FIRST by crossing that road. - Mike Ciance [more]
Unread 22-04-2016, 09:06
Trapazium Trapazium is offline
FRC #3735
Trapazium is an unknown quantity at this point
Talon SRX Motor Current
It there a way to read the Motor Current Amps while motor running.
via CAN on Talon SRX Motor
Unread 22-04-2016, 09:13
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Talon SRX Motor Current
Use the PDP singleton class and the getCurrent(channel) method.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 22-04-2016, 09:26
FRC #3735
I found C code examples
Anybody can give tips or examples on JAVA..
Unread 22-04-2016, 10:17
AKA: Nick Schatz
Here's the Javadoc link:
http://first.wpi.edu/FRC/roborio/rel...rent-byte-int-
Unread 22-04-2016, 10:20
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Or you could use the CAN Talon's internal current sensor:
http://first.wpi.edu/FRC/roborio/rel...utputCurrent--
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Alternatively, you can just call:
myTalon.getOutputCurrent();
Unread 24-04-2016, 20:10
FRC #3735
We were able to use to myTalon.getOutputCurrent();
This worked out well for Dual Motor Shooter...
We found One Motor has lower current and thus shooter was spinning balls to one side.
We adjusted the Each Motor Speeds via motor current since we dont have encoders..
So for a quick an dirty shooting with dual motor use motor current feedback to fine/tweek the shooter shoot direction...
Unread 24-04-2016, 21:09
AKA: Nick Schatz
The Talon SRX has a current PID mode as well. Might be worth looking into.
