Go to Post In other words, don't worry about the results but strive for excellence in the way you live your life and everything you do. - Paul Copioli [more]
Unread 23-04-2016, 15:52
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
Re: PDP - LED's
Originally Posted by rtfgnow View Post
Can you expand on what you mean by "works"? What do the LEDs do when it is powered? Is your roboRIO power slot outputting the proper 12 volts?
If you think you might want CTRE to replace it, I would suggest you call them on Monday before opening it up.
The robot runs but can be intermittent at times, showing a "No Robot Code" error then going back to "Teleoperated Disabled" suggesting a power cycle occurred. At our regional, we had a CSA help us with it (I think he even asked Mark McLeod about the behavior) and ended up suggesting that the problem stemmed from our 10 amp red fuse slot being "jammed". We were issued a temporary replacement and all worked well with it.
If I'm not mistaken the two LEDs flash orange/green (it's been a while). We got in contact with CTRE after the regional and they said it was a software issue with the device ID being set too high last year (2015)? They told us to "Disconnect CAN bus between the robot controller and the missing-ID-device. Then power-cycle or reboot the roboRIO. Navigate to the roboRIO's webpage and wait until page fully renders. Now reconnect CAN bus and manually-refresh the browser until device appears."
That didn't solve it either.
Unread 23-04-2016, 16:14
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: PDP - LED's
According to the user guide, orange/green LEDs indicate you need to upgrade the firmware, but you cannot do that if you cannot see it in the web dashboard.
Important things to check are that you have the wires stripped to the proper length before inserting them into the weidmuller connectors, the wires are going into the right ports based on high/low (yellow/green) and you have a terminating resistor. If this is all correct I would again contact CTRE.
I am doubtful that the issues with CAN communication are related to the odd behavior you saw from your robot. The 10 amp fuse and slot could cause the roboRIO to reboot if there was an intermittent connection. If you only saw "No Robot Code" but not "No Robot Communication" than I would evaluate your code for any place where an error would be thrown instead of looking for a case of the roboRIO rebooting.
