Go to Post STICK WITH WHAT WORKS FOR YOU!!! - Will Hanashiro [more]
Unread 24-04-2016, 12:01
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: GT2 PROFILE 3-D CAD FILE FROM SDP/SI.
The actual tooth profile is not hard to work out. You can CAD a single tooth correctly and then create a pattern to make the remaining teeth. This also allows you to have any custom drive center that way. If 3d printing, having your own CAD allows you to adjust the drawing for the variations in the final printing geometry. (Ours shrinks a bit when cooled).
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 24-04-2016, 16:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
WE HAVE ORDERED PULLEYS FROM THEM BEFORE, AND WERE OK ON THE PROFILE! 192 ALSO USES THEIR PULLEYS WITHOUT ISSUES, PERHAPS YOU COULD CONTACT THEM.
SOMETIMES WHEN I OPEN CAD FILES FROM SDP-SI, THE TOOTH PROFILES LOOK MESSED UP OR PULLEYS ARE MISSING TEETH; IT'S NOTHING TO WORRY ABOUT.
