Go to Post Now its up to us to show that what we shout from the high places is also true down on the street. - KenWittlief [more]
Unread 24-04-2016, 21:31
kingca kingca is offline
FRC #0108 (SigmaC@ts)
Rookie Year: 2015
kingca is an unknown quantity at this point
Grip
Is it possible to use Grip without using Java because this year our team decided to use C++ or do we need to convert code into Java in order to use Grip.
Unread 24-04-2016, 21:34
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Grip
There are C++ examples listed here:
http://wpilib.screenstepslive.com/s/...-networktables
Unread 24-04-2016, 21:42
Lili_1868 Lili_1868 is offline
Autonomous Director
AKA: Lili Sun
FRC #1868 (Space Cookies)
Rookie Year: 2016
Lili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of lightLili_1868 is a glorious beacon of light
Re: Grip
Our team uses C++ and GRIP.
Unread 24-04-2016, 21:59
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Grip
Yes you can.
GRIP runs using Java, but it's output is through Network Tables.
You can read those values from the Network Tables in C++.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 24-04-2016, 22:21
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Captain
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Grip
GRIP is a separate application. It outputs values using NetworkTables. You will need to install Java on the roboRIO (or whatever device you are running GRIP on)
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 12-05-2016, 15:01
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: Grip
You can definitely do it. Here's our vision tracking code.
