Re: pic: WIP 3 CIM 2 Speed All Belt Cim Above Tube Gearbox
TBH I haven't done any math for the strength of the belts. Again, I didn't intend this to be a production gearbox and more an experiment/proof of concept/CAD practice. I'll post the tooth totals though. I think it's 18-50, 18-30, and then either 20-50 or 30-40. What about the paramedics are flimsy? I can always add a support on the back of them. Edit: I realize that the pictures pneumatic is orientated wrong. The fittings should be either vertical up or horizontal to the outside of the gearbox. Last edited by Colin Small : 24-04-2016 at 23:12. |
The pneumatic layout on the GRT gearbox this year was designed for just one pneumatic and designed to deal with this moment. There are two on there because we were having a bit of trouble shifting in a few extreme conditions so added the second for safety, there is improvement to be made to get back to one. |
Apparently three days ago I went on and designed a similar gearbox: inverted, two-piston shifting using a dog, except that the thing runs on gears entirely. Here's a picture: ![]() Regarding how to reduce the number of pistons to one, I'm not so entirely sure, but to reduce the bending force to the shifting plate, the piston cannot be offset from the shaft. However, by doing so, you have to consider that the wheel is also going on the output shaft, and if the piston sticks out too much, it will hit. Also, the other issue that would come up would be connecting the piston to the shifting rod. Tried that once, and I hated it. You could add a third plate for spacing like what 254 did with their gearbox this year. Then piston-wheel collisions wouldn't happen anymore. Just some things that I thought of, having designed 3+ of these inverted gearbox. Hope this helps! |
Anyways, I like your design! I want to try doing the ribbing between mounting/clearance holes but it's never worked out well for me. |
For it to work smoothy the goal is to have the moment supported by something other than the pneumatic shaft and shifting shaft. The strength of the connecting plate isn't a huge concern, it can be made stiff, the joints are the problems. There are a few different ways to do this. The option chosen for the gearbox this year involved flipping the pneumatic, having the plate mounted to the back of the pneumatic and have the whole cylinder move inside a plastic bushing that took the load. This can be seen pretty clearly with more examination of the posted gearbox picture.
