gyro
the above message has a manual override switch. here is just the gyro code.
If sensor1 > 180 then balancing_motor = 67 else If sensor1 < 74 then balancing_motor = 183 else If (sensor1 < 137) and (sensor1 > 117) then balancing_motor = 127 endif endif endif |
| gyro code | odin892 | Programming | 2 | 08-04-2003 14:50 |
| Help with the gyro chip | Team852 | Electrical | 1 | 10-01-2003 22:31 |
| Is any team using the gyro chip? | Ragin_Kage | Kit & Additional Hardware | 4 | 10-04-2002 12:11 |
| Voodoo Gyro Chips... | Ghetto_Child | Technical Discussion | 3 | 01-02-2002 16:39 |
| Have YOU used the gyro chip? | FotoPlasma | Technical Discussion | 10 | 31-01-2002 13:26 |
