Go to Post There's more than one way to skin a cat. - Al Skierkiewicz [more]
Unread 08-04-2003, 09:59
odin892 odin892 is offline
#0892 (team ASCII: All Students Challenging Intellect and Ingenuity)
odin892 is an unknown quantity at this point
gyro
the above message has a manual override switch. here is just the gyro code.
If sensor1 > 180 then
balancing_motor = 67
else
If sensor1 < 74 then
balancing_motor = 183
else
If (sensor1 < 137) and (sensor1 > 117) then
balancing_motor = 127
endif
endif
endif
gyro code odin892 Programming 2 08-04-2003 14:50
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
Is any team using the gyro chip? Ragin_Kage Kit & Additional Hardware 4 10-04-2002 12:11
Voodoo Gyro Chips... Ghetto_Child Technical Discussion 3 01-02-2002 16:39
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
