Go to Post You can't derail a thread that had no "rails" to begin with. - bkahl [more]
Unread 25-04-2016, 13:22
Colin Small Colin Small is offline
FRC #0114 (Eagle Strike)
Team Role: CAD
Colin Small is an unknown quantity at this point
Re: pic: WIP 3 CIM 2 Speed All Belt Cim Above Tube Gearbox
Originally Posted by KohKohPuffs View Post
Also, the other issue that would come up would be connecting the piston to the shifting rod. Tried that once, and I hated it. You could add a third plate for spacing like what 254 did with their gearbox this year. Then piston-wheel collisions wouldn't happen anymore.
Just some things that I thought of, having designed 3+ of these inverted gearbox. Hope this helps!
Not quite sure what you mean by a third plate or piston-wheel collisions. The cylinders are contained inside the gearbox so they won't be hitting any wheels.
Anyways, I like your design! I want to try doing the ribbing between mounting/clearance holes but it's never worked out well for me.
