Go to Post Also, I'm tired of the "FIRST is a simulation of the real world"-- it isn't. If the real world was like FIRST, there wouldn't be any need for this organization. - cadandcookies [more]
Unread 25-04-2016, 14:32
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Re: pic: GBX-139, budget swerve
Originally Posted by Conor Ryan View Post
Any evidence (either way) that the delrin/acetal bevel gears can hold up for a full event?
Also, are you sure you want a 775 as your main drive motor? Your chance of burn out is much higher and you really don't want to take that type of risk. The way the motor is designed makes it a much smarter choice for any application where it won't be stalled for a significant length of time. Although you probably won't stall much in a swerve drive, you will be running close to stall conditions frequently and that will generate a large heat load.
Awesome execution either way.
"It is made for a 70-80lb demo chassis, although it is possible to convert it to a competition design by swapping bevel gears and motors." -asid61
