Go to Post "You know, if we shoot the flame thrower out of the back of the car while driving down Main Street at 2:00am, we are probably going to get in a lot of trouble..." - dlavery [more]
Unread 14-04-2016, 21:20
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Re: Catapult issues with boulders
Data collection is under way...
https://goo.gl/photos/h2Hm3HTgxubcyZep7
Unread 14-04-2016, 21:30
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
Have you tried using the exact same ball and shooting it a dozen times? We have a pnumatapult and have 0 issues with ball changes.
Unread 14-04-2016, 22:32
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Ok, going to need you to explain this one a bit for me. We were relatively solid with getting the high goal from the defenses during our first two events, but then at our third started having this issue. Wouldn't it be better to make sure that we could shoot multiple balls consistently, rather than shooting the same exact ball multiple time which would not establish whether it could handle different ball quality/properties?
Unread 14-04-2016, 22:43
It's all about seeing if your mechanim has degraded or changed at all. If it can shoot the same ball to the exact same spot it shows a different issue.
Unread 14-04-2016, 23:14
wilsonmw04's Avatar
Coach
Let me explain the test. We have no issues shooting a single ball. Out of 20 shots, 19 are consistent. Our mechanics have not changed. What you see in our data points is the 30+ shots we took tonight under the watchful eye of a 240 FPS goPro. The yellow tape is the y-axis value of each shot. The paper records the variables of the shot. You can see that as balls wear our shooter gives them a higher trajectory. Why that is is TBA. We haven't looked at the video yet.
We did find out that we have enough adjustment on the pan to get the shot where we want it. The issue was interference with a secondary part. We are going to look at the film, do some analysis and come up with a few more tests.
We will figure this out. More to come. stay tuned.
Unread 14-04-2016, 23:17
Do you have a mechanism on the bot that "packs" the ball?
Unread 14-04-2016, 23:26
wilsonmw04's Avatar
Coach
please explain what you mean by "pack"
Unread 14-04-2016, 23:31
We have a device that compacts the ball by about 4" every shot. This seems to have been an integral part of our consistency.
Unread 14-04-2016, 23:46
wilsonmw04's Avatar
Coach
I need to see what you are talking about. what does compression have to do with a shot?
Unread 15-04-2016, 16:09
wilsonmw04's Avatar
Coach
We have our video from last night. I'm going to do some data analysis on it tonight. If you see anything glaring, give a yell.
https://www.youtube.com/watch?v=OgWG...ature=youtu.be
Unread 25-04-2016, 13:00
wilsonmw04's Avatar
Coach
Greetings Folks,
Just wanted to give you an update. We found our issues. We found that we were bending our frame with each shot. The anchor to our seat belt was bending towards the shooter and the cylinder mounts were bending the entire frame down significantly. We reinforced the frame with a 1/8" thick patch plate. That worked for a day. Then the shooter went back to it's old habits because that new plate bent as well. We decided to go the route of overkill. We went with a 1/4" Aluminum plate reinforced with 1/8" angle along the long axis of the plate. The shot now makes a satisfying "ting!" when we shoot. Roughly 100 shots and not bending. We have a consistent shot at the outworks now.
he's to hoping we come out of the gate shooting!
Unread 25-04-2016, 14:01
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Thanks for sharing the solution. Educational for us all!
Unread 25-04-2016, 18:34
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
Greetings Folks,
Just wanted to give you an update. We found our issues. We found that we were bending our frame with each shot. The anchor to our seat belt was bending towards the shooter and the cylinder mounds were bending the entire frame down significantly. We reinforced the frame with a 1/8" thick patch plate. That worked for a day. Then the shooter went back to it's old habits because that new plate bent as well. We decided to go the route of overkill. We went with a 1/4" Aluminum plate reinforced with 1/8" angle along the long axis of the plate. The shot now makes a satisfying "ting!" when we shoot. Roughly 100 shots and not bending. We have a consistent shot at the outworks now.
That's interesting and I'm glad you found a solution. However, I'm not sure how the bending of the frame only impacts new balls and not old balls. Any theories on that?
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 25-04-2016, 23:07
wilsonmw04's Avatar
Coach
It is odd. What I can tell you is that older balls still have a higher trajectory than new balls. What we noticed is that older balls seem to leave the pan quicker, we assume, getting a slightly longer lever arm from the motion and going higher.
With the changes in the support of the cylinders, all shots have more backspin. We assume that means they are rolling off the pan more. We haven't had time to do slow-mo video after the fix.
Hopefully, we see the same changes on the bagged robot Wednesday.
Unread 26-04-2016, 00:11
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Greetings Folks,
Good luck! This team will be spooky if the consistency bug goes away.
