Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Unread 04-24-2016, 07:10 PM
juju_beans's Avatar
juju_beans juju_beans is offline
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is an unknown quantity at this point
Off season T-Shirt Launching Tank Robot
As an off season robot, 3647 is making a Tank bot that shoots T-Shirts!
So far we've caded up the entire base and the turret is still being worked on
https://imgur.com/pwvzBGG
Side view: https://imgur.com/2hWbAKr
Yes, that is TWO batteries you are seeing, we've made a parallel battery connector to power the whole thing
Turret
https://imgur.com/WhsL0UQ
Each shell falls down and after the t-shirt is shot, there is a small piston on the side to shoot it out of the ejection cover.
Shooting test with only a air tank, valve, and barrel
https://youtu.be/LVJDTHKDO3s
Shooting Specs:
110 psi (though we will probably shoot at a lower psi)
1inch sprinkler valve
1 gallon tank (When shooting at 80 psi it drops to about 60)
For air storage there is a huge 5( I think) gallon tank
Some actual build pictures:
VHB Tape is apparently really, really strong!
http://imgur.com/Bp3wYWq
Wiring looking nice
http://imgur.com/p9hF0ec
Storage tank mounted
http://imgur.com/xmi4PFv
PWM Cables routed
http://imgur.com/5MvsXxP
http://imgur.com/bq1Qzzo
Big thanks to hectorcastillo for the retention clip CAD (https://grabcad.com/library/roborio-...tention-clip-1)
General overview
http://imgur.com/FqQkIrm
Specs:
6 CIM West coast drive for Treads ( no tank drive as the drivetrain is just too long to be powered like that)
10 Victor 888s
Roborio controller
Frame size: 23w x 35l
still have a ways to go!
This is safe... right?
Unread 04-24-2016, 07:56 PM
NotBattleBots's Avatar
NotBattleBots NotBattleBots is offline
AKA: C. Mathis
FRC #5132 (Roboclovers)
NotBattleBots is an unknown quantity at this point
Re: Off season T-Shirt Launching Tank Robot
Looks like a lot of great work has already gone into it! Have you looked at the possibility of using a scuba tank to supply air? They are a lot higher pressure, but the standard first stage scuba regulator (the part that attaches to the tanks) brings it down to around 100psi which you can use a standard regulator to handle. The only think that was tricky on ours was an adapter to go from the scuba fitting to 1/4 npt I believe. It was nice to have the pressurized volume to shoot hundreds- if not thousands of shirts before worrying about running out of air. Overkill-- maybe, not having to worry about compressors-- priceless.
We also are using a vex cortex and controller to control the robot. It takes less time to boot and connect, and conserves roborio's for competition or practice bots. We continued to use the blue pdp like yours though.
Unread 04-24-2016, 11:58 PM
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
That looks expensive, but I'm sure it will be AWESOME when it's done! I look forward to seeing more pics of this!
Unread 04-25-2016, 12:02 AM
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Cue argument over PVC barrel
Unread 04-25-2016, 12:17 AM
Translation: It'll be pressurized-air-rated material X barrel before long. Or else encased in a Lexan box. I might suggest ABS if it's got the proper ratings.
Just one of those things that need to be thought about early rather than late. OTOH, barrels aren't all that hard to swap out if needed...
Unread 04-25-2016, 12:20 AM
juju_beans's Avatar
Rookie Year: 2016
We thought about it but it is fairly expensive. We also have a very fast air compressor that will fill the entire thing in about 1ish minutes.
We already have the stuff do we don't really want to buy anything more, and if we need the roborio we'll just take it off.
I've read quite a bit about this, and we've decided to use the regular pneumatic tubing from the storage tank to the shooting tank, metal pipe from the storage tank to the valve, and for the barrel we'll either use some stiffer drain pipe stuff (which is fairly soft and appears to be made of polycarbonate sheet) or metal.
though cue my signature "this is safe... right?"
Unread 04-25-2016, 12:38 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Air is MUCH more compressible than water. This means that compressing a volume of air to 120 PSI takes several thousand times more work than compressing the same volume of water to the same pressure. As a consequence, there is MUCH MUCH MUCH more energy to be released.
In general, only use devices rated for air pressure (not water pressure) to handle air. In particular: DO NOT USE A "SPRINKLER VALVE" to control air pressure. While the pressure/force is no greater, the stored energy in air is three or four orders of magnitude higher than that stored in water at the same pressure. Do not use PVC or other random plastic containers to store air.
For a T-shirt launching air cannon, I recommend at least a 3/4" (and preferably a 1") AIR-rated solenoid, and that all hoses be of similar diameter. With a 3/4" solenoid valve, 3/4" tubing, and 60 PSI pressure, we have thrown t-shirts and foam footballs over our press box onto 9th street; it is unlikely that you will need greater pressure to get t-shirts into the top levels of your stands.
Unread 04-25-2016, 08:42 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Have you thought about what the scrub from the tank treads are going to do to your football field?
Looks like a cool project with a lot of thought
Unread 04-25-2016, 09:53 AM
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
I REALLY want to see how your auto loader design works! is it sealed on the edges in any way?
I was playing around with a quick load breach design for a "Man Portable" multi shot cannon, and this might be the solution to pull it off smoothly!
Unread 04-25-2016, 10:31 AM
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Really good string here. We built a t-shirt cannon a few years ago and only used it once.
Team pays about $18 for our t-shirts (yes, seems high to me too) and we'd shoot them to kids at a football game that didn't even want them.
Turned out to be a fun project, but not such a good idea.
Gotta figure out a way to shoot t-shirts that someone else pays for.
Unread 04-26-2016, 01:07 AM
Soko's Avatar
Soko Soko is offline
FRC #4787 (Axiom)
Rookie Year: 2015
Soko is an unknown quantity at this point
We recently finished our own shirt cannon bot, and (like other posters have said) I'd recommend trying to get your hands on a SCUBA tank. We asked a local dive shop if they were willing to donate on (it's a good cause) and they gave us an old one AND a first-stage regulator, too. The capacity is enormous; I'd estimate about 80-100 shots at our usual 70 psi. The only hassle is getting it refilled, but we know in advance when it needs to make an appearance and can plan accordingly.
In addition, you're definitely going to want to grab an air-rated valve. We found a good one for <$25 on amazon (even has free shipping) that is rated for well beyond any pressure you're going to shooting with, and is also very quick to open and close.
Looking pretty great so far though, the turret mechanism and tracks are going to be a hit when you unveil it.
Unread 04-26-2016, 12:13 PM
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
You can buy shirts for <$5.00 in qty. Maybe not what you want for your team shirts, but for giveaways, they work. Buying overstocks, seconds, and having your school's graphics art department print them is a possibility as well. Talk to the football booster club. They can get shirts from their sponsors. Sponsors like for there shirts to be shot into the crowd.
Unread 04-26-2016, 02:08 PM
hrench's Avatar
AKA: Bob Hrenchir
Actually a great idea, shooting sponsor shirts.
Another ironic problem we had was we didn't really have any robotics kids that wanted to go to the football games.
But it does give your team more visibility in the school and might help some of the sports-people tolerate you.
Might dust off the old robot and try that....
Unread 04-26-2016, 02:43 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
This concept reminds me a lot of this one I posted a few months back. I hope when it's finished you'll post a video of the feed system running.
On the note of scrub that was brought up earlier, if you offset the centermost rollers of the tank drive the resulting wedge functions much like a typical dropped center 6wd.
Unread 04-26-2016, 09:59 PM
juju_beans's Avatar
Rookie Year: 2016
We have a few pep rallies during the year (which includes throwing t-shirts into the crowd) and also many sports events which we can probably get the school to give us t-shirts.
Our football field is turf instead of grass so it won't rip stuff up. We would also probably prefer to do these things in the gym instead.
Thanks for the reminder! I'll be sure to remember to put a center drop. Luckily we still have not made the two side panels!
We still have quite a bit of stuff to buy like the metal side panels (which also need to be sent off to be cut!) , some more tank pulleys so the chassis might be a bit of time but we'll probably start on the turret very soon!
