Re: #FIRSTChampLIVE Announcement
Will the Opening Ceremony be broadcasted? If so, which video/stream on Game Sense will be covering it?
But don't quote me on that... |
So coverage would be on the "Einstein field" on TBA's GameDay?
Yes. I believe it will be on all the division streams.
Einstein is actually just the #FIRSTChampLive stream on GameSense.
Will practice matches be streamed?
#7
#8
Is there somewhere that has a list of the MC's for each division ( or just all of the MC's if they arent strictly assigned?)
Also, the stream is great. One issue: The stream stutters. A Lot. Besides this the quality is great, already really nice angles and camera setups for the practice matches! Last edited by MikLast : 27-04-2016 at 19:52. |
#9
![]() Last edited by Chris_Ely : 27-04-2016 at 20:25. |
#10
Every other stream is smooth as butter. I assume because this one has so many more viewers is why it's stuttering quite a bit.
#11
Hey everyone! Thank you for watching the broadcast this evening! We have some changes we are making to get the occasional stuttering to go away.
Can't wait to see everyone for the start of FRC matches tomorrow! |
#12
I really like the show format so far! EDIT: It is probably just having 9 streams running at the same time, carry on. Last edited by Chris_Ely : 28-04-2016 at 10:57. |
#13
I just watched on high quality for about 20 minutes and did not have any streaming issues.
Video Resolution: 1280 x 720 Display Resolution: 620 x 378 FPS: 30 Skipped Frames: 1685 Buffer Size: 6.93 sec. Latency to Broadcaster: 15.66 sec. Latency to Encoder: 8.66 sec. Playback Rate: 1302.23 Kbp |
