Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
  #33   Spotlight this post!
Unread 26-04-2016, 22:36
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Comparison of DIV MAX OPRs
FWIW
Ten million 75-team samples randomly drawn from 600-team CMP population; 2.5% had average OPR greater than Newton's.
Interestingly:
mean of max OPR of 600 CMP teams = 37.331
std dev of max OPR of 600 CMP teams = 12.287
predicted std dev of the means of the 75-team samples = 12.287/sqrt(75) = 1.4187
mean OPR of Newton = 40.1149
predicted Zscore of Newton = (40.1149-37.331)/1.4187 = 1.9623
area under normal curve between mean and 1.9623 = .4570
predicted probability = 0.5 - 0.4750 = 0.025 = 2.5%
Interesting. 3 methods provide the same result (Ether's two methods and my method #1* 2.5% is 1 in 40)
I swear, I didn't look at Ether's answers before I did my simulation.
Dr. Joe J.
*which, I thought should be the better metric - method 2 was more tailored to be stacked in the way that Newton was stacked, so of course it is more rarely observedd.
Team #88, TJ2
