Go to Post Don't be affraid of trying new things... Even if people say you are crazy, even if you get insulted, even if it involves a lot of time and money, try it. You can't know if it'll work or not if you didn't try it yet. - EDesbiens [more]
Unread 27-04-2016, 00:12
ROULT ROULT is offline
AKA: pepemanboy
FRC #4403 (ROULT)
ROULT is an unknown quantity at this point
Load in and pits
Hi everybody
We have a question regarding the schedule for tomorrow...
It says that load in can be done at 1 pm.
Can we start working on the robot at that time?
Or do we need to wait for 4:00pm?
Thanks and good luck to all!
4403
Unread 27-04-2016, 00:49
Jaci's Avatar
Jaci Jaci is online now
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Re: Load in and pits
You have to wait until 4:00PM to begin work on your Robot, although you can get it inspected between 1:00PM and 4:00PM if memory serves me correctly.
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 27-04-2016, 01:13
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
I'm reasonably certain that this is part true. You can't have anyone in the pits other than your 5 load-in members between 1 and 4, and most teams use the time to set up their pit......however, it's not illegal to work on the robot with the 5 load-in members. The lack of inspector-approved unbagging helps a lot with that.
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
Unread 27-04-2016, 06:02
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
I am a robot inspector at Champs, and you can start working on your robot right away. They are having us ready to start inspections at 1:00 pm.
So, uncrate and unbag your robot right away, and get in the weighin line as soon as possible.
BTW: If you can get your robot inspected, it also means you can work on your robot too. So, if you have to attach 20#, then attach 20#, and then get in the line to weighin.
Unread 27-04-2016, 06:05
mjc49's Avatar
mjc49 mjc49 is offline
Coach - Team 3042
AKA: Mike
FRC #3042 (Cobalt Catalyst)
mjc49 is an unknown quantity at this point
Yes you may start working on your bot right at 1. Be sure to move your crate to the end of the aisle as soon as you are ready for it to be moved to storage.
(2013-Current) Coach-Team 3042 Cobalt Catalyst, MN North Star Regional Winners (2014 w/2177 & 4778, 2016 w/2175 & 3130)
2017 - LRI: MN North Star Regional
Unread 27-04-2016, 07:02
araniaraniratul's Avatar
araniaraniratul araniaraniratul is offline
294-Alum
AKA: Arani (Ron) Bhattacharyay
araniaraniratul is a jewel in the rougharaniaraniratul is a jewel in the rougharaniaraniratul is a jewel in the rough
Send a message via AIM to araniaraniratul
@rich2202, any idea when the Practice Fields are free to use?
The Greybots
973
- Mentor
Beach Cities Robotics
294
- Student/Mentor
The Sloth Bears
5499
- Mentor
Unread 27-04-2016, 08:21
ATannahill ATannahill is offline
AKA: Alex Tannahill
From the A to Z Guide:
Practice Fields: On Wednesday, practice fields are only open for robots that have completed inspection and will be available for tethered operation on a first come, first served basis. A maximum of 15 minutes per use per turn is available. On Thursday and Friday, if you wish to practice running your robot during practice matches on the full Practice Fields, all spots will be filled via first come, first served filler lines available at the entrance to the fields. You must run your robot wirelessly on the practice field on Thursday and Friday. Remember to review your team's match schedules before getting in line for the practice field. Additional practice areas will be available for first-come-first-served tethered operation and can be found on the venue map. Please keep safety in mind when using these areas. Detailed information about practice fields can be found here: http://www.firstchampionship.org/sit...ice-fields.pdf.
The link from the A to Z guide does not seem to be working, this appears to be the proper link.
- Arizona North
Unread 27-04-2016, 08:29
jodge1706's Avatar
jodge1706 jodge1706 is offline
Captain | Driver | Bench Grinder
AKA: Gavin
FRC #1706 (Ratchet Rockers)
Team Role: Driver
jodge1706 is on a distinguished road
I am volunteering and are assigned to work practice fields. They said for practice field volunteers to be ready to work at 5, so I imagine sometime near there maybe...
Just because you graduated doesn't mean you have to stop being a student....right?
2016 Championship Volunteer
2016 Robot: "MASTERKEY" | St. Louis Regional Semi-Finalists | Rocket City Regional - Spirit Award / Quarter-Finalists
Unread 27-04-2016, 12:14
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
What about camera calibration, is there a time set out for that?
Unread 27-04-2016, 12:21
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
8:00 am to 8:30am tomorrow
http://www.firstchampionship.org/sit...c-schedule.pdf
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
Unread 27-04-2016, 15:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I actually think the answer to this is vague, but it probably doesn't matter at this point because it's past 1PM and teams are right now loading in and working on robots regardless.
Anyways, my reasoning is that R16-C says you can only work on the robot while the pits are open, and the FRC team schedule says the pits aren't open until 4PM. Of course the A to Z guide contradicts that an says the pits are open (for Team Load-in) at 1PM.
On the one hand, giving people more time to work on things is good. On the other hand, that could be a 3-hour head start for the people that were at the head of the line. Which is pretty significant on such a short practice/inspection day.
Unread 27-04-2016, 15:49
346CADmen's Avatar
346CADmen 346CADmen is offline
FRC #0346
346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold
I have full appreciation for your statement. Had the same issue at CHS District Champs. Load in at 5, how ever many teams must have been let in early as their elaborate pits were fully set up at 5:15. This allowed them that much more time to work/practice.
My suggestion is to allow a given time for load in/set up then an un-bag time at a later point.
Unread 27-04-2016, 15:58
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Since I have been going to Champs (2010), you have always been able to start work as soon as you uncrated your robot. What is a bit confusing is Pits opened for teams (limited to 5) at 1:00 and to the public at 4:00. Anyway First makes & enforces the rules. They can interpret them any way they want.
