Go to Post Let's let FIRST bring us together as a whole rather than separate us into parts eh? - sanddrag [more]
Unread 28-04-2016, 16:38
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
Blue Alliance API OPR
Does the Blue Alliance API provide teams' OPR values, or will I need to calculate them myself?
Thanks!
Unread 28-04-2016, 16:39
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Blue Alliance API OPR
It appears to be provided. See event stats.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
It's all there for you!
Take a look at the "Event Stats Request" section of http://www.thebluealliance.com/apidocs
Unread 28-04-2016, 16:50
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
It appears to be a little funky on Archimedes at least. Earlier it was listing my team's OPR as 115.something.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 28-04-2016, 16:59
foote stepped in
AKA: E. Foote
FRC #0868
You generally need to play at least 6 matches before OPR has any meaning. Before then it is a garbage value.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 28-04-2016, 17:10
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
Thanks! I should have looked harder.
Unread 28-04-2016, 17:27
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Not a bad rule of thumb, but it depends on the size of the event. With larger events, each team needs to play more matches before getting the same level of accuracy.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 28-04-2016, 17:45
http://www.chiefdelphi.com/forums/sh...3&postcount=21
Unread 28-04-2016, 22:07
foote stepped in
AKA: E. Foote
FRC #0868
On each of those pretty graphs, where would you estimate the point OPR stabilized? I'd eyeball around 5-6 matches per team, although some sort bound on the delta opr / match might give a more accurate answer. Maybe it is stable once all OPRs don't change more than 2-5% after a match?
Unread 28-04-2016, 22:21
Since each match generates 2 OPR equations (one for red alliance and one for blue alliance), you need at least T/2 matches to be played (where T is the number of teams) to get an overdetermined system of equations. As you can see from the graphs, it takes a bit more than T/2 to settle down.
But... did you look at the rest of that thread? Eugene Fang came up with a clever idea for getting around this limitation so that a stable OPR can be introduced right at the start of the event... and as matches are played the new data is used to refine the OPR. That new algorithm is used for the match predictions at the TBA site.
