Go to Post Indeed, the more ways you fail, the more ways you know something doesn't work.:) - Steven Sigley [more]
Unread 29-04-2016, 01:01
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
C.Lesco will become famous soon enough
Cleaning Wheels
Is there an easy way to get paint and dirt off of the stock andymark 6" KOP wheels? It would greatly appreciate it if you could help us.
Rookie Allstar winner North Bay regional 2016 [Team 5870]
Driver 2015 [Team 4814]
Lead Driver 2016 [Team 5870]
Build, Design and Engineering Captain 2016 [Team 5870]
Mentor 2017 [Team 5870]
Unread 29-04-2016, 01:03
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Cleaning Wheels
Paint, not a clue. But for dirt we used alcohol tissues last year for colson wheels, so those might work.
Unread 29-04-2016, 08:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Cleaning Wheels
Treads are the whole wheel? For dirt any spray cleaner and rags. Abrasive pads for stuff that is stuck on. For paint, chemical methods are out. So that leaves sanding/polishing. Paint generally doesn't stick particularly to the rubber tread. Or the high resource way: order new ones.
Unread 29-04-2016, 18:17
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: Cleaning Wheels
Graffiti remover works on almost everything. Haven't tried that aplacation
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 29-04-2016, 21:33
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Cleaning Wheels
I woud try isopropyl alchol if it won't damage the wheels. If that doesn't work, maybe try WD-40 unless it's on rubber, as a lot of WD-40 on rubber can dry it out.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 29-04-2016, 21:41
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: Cleaning Wheels
The KOP wheels are TPU rubber, so I would use WD-40 at your own risk.
Unread 01-05-2016, 10:27
happyWobot happyWobot is offline
FRC #0122
happyWobot is on a distinguished road
Re: Cleaning Wheels
We have used Purel hand sanitizer in the past to clean rubber Tetrix wheels. It contains alcohol but also glycerin or some other agent (can't remember). But of course, use at your own risk. Is it cost prohibitive to just replace the wheels?
Unread 01-05-2016, 11:10
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: Cleaning Wheels
What about on pnuematic wheels?
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 01-05-2016, 11:20
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: Cleaning Wheels
For our harvester wheels, last year I liked to run the wheels and hold a wet nap on them to let the wheels clean themselves.
Head Programmer / Driver
Unread 03-05-2016, 21:30
FRC #0122
Re: Cleaning Wheels
No, I would not recommend using alcohol or any chemical of that sort on pneumatic wheels intended for robots.
Unread 03-05-2016, 21:38
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Re: Cleaning Wheels
Well, do you know how I should clean them. Our bots yellow wheels are compltley coated in black stuff.
Unread 03-05-2016, 21:44
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Cleaning Wheels
Why do you say that? We had success this year, but does it reduce the integrity of the tire somehow?
Unread 04-05-2016, 12:34
RoboChair's Avatar
AKA: Devin Castellucci
Re: Cleaning Wheels
Two Words
Pressure washer
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 04-05-2016, 12:39
Chris is me's Avatar
AKA: Pinecone
Re: Cleaning Wheels
Rubbing alcohol and a shop rag is a great first pass solution for cleaning off wheels, intakes, really anything. Rubbing alcohol will not damage pneumatic wheels.
We used Purel hand sanitizer on our intake belt - there was some tacky adhesive (that would never contaminate a ball) which the hand sanitizer seemed to re-activate somehow whenever we used it.
Unread 04-05-2016, 18:50
FRC #0122
Re: Cleaning Wheels
The concern is that a pneumatic tire cover is under pressure. If it were a typical rubber wheel like that on an automobile or bicycle tire I don't think it's much an issue to put foreign chemicals on it. We do it all the time with wheel cleaner or tire bright intended for that purpose. But tire covers like those used this past season are very thin and made of a different kind of rubber. Under pressure they stretch and I would make the presumption that expansion would make them more absorbance of chemical if they are porous. Was really disappointed by how quickly some of those tires demonstrated wear.
The point is that from a safety concern it's better to err on the side if caution with something under 40-60 lbs pressure. Admittedly if the cover failed you'd still have the tube to contend with. I knew someone when I was much younger that survived an auto tire failure during repair. It's a really scary thing.
I second the idea regarding the pressure washer. Far more preferable than chemicals. But deflate and disassemble before you do that. Pressure washer can cut right through things if it is soft enough and at the right angle. On that regard whatever you do, never let hands or feet get anywhere near a pressure washer nozzle. It's a very dangerous injury if it cuts you.
