Go to Post Every team should have a rule about not shouting "ROBOT!" when transporting a robot around the pits/arena. - frasnow [more]
Unread 04-29-2016, 03:55 PM
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: pic: Another stripped VexPro gear
Hey FRCGuy are you sure you don't want my 2 lightly used 24 tooth Vex gears?
Cause...
It's probably too late for me to broach you steel gears.
I also don't have 24 tooth steel gears to start with and I doubt I can get them fast enough.
Going to put these on my list of 'coming soon'...
Unread 04-29-2016, 04:15 PM
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Just in case it hasn't happened yet ...
I'll bet the VEX folks would like to hear from you. I'm guessing that they will want to know if
A) they need to either include a caution with their parts to help users avoid exceeding the loads the parts are designed to sustain, or
B) they need to investigate a batch of parts that might have been manufactured badly, or
C) they perhaps need to tweak their product's design.
If you are at the championship, I'll bet they are there too.
Blake
Unread 05-02-2016, 10:27 AM
LSanchez439's Avatar
LSanchez439 LSanchez439 is offline
AKA: Leonard Sanchez
FRC #3481 (Bronc Botz)
Team Role: Operator
Rookie Year: 2015
LSanchez439 is an unknown quantity at this point
Cause...
When you say 'broach' them some steel gears, what exactly are you referring to?
Unread 05-02-2016, 10:39 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You can Google "broach" to find some examples, but in this case, it is pushing a hex shaped cutting tool through a round hole to make a hex shaped hole.
Unread 05-02-2016, 11:23 AM
techhelpbb's Avatar
Buy a gear with a 1/2" round hole (also maybe a keyway) and push broach it 1/2" hexagonal.
The push broach looks like this (this one is from Dumont):
http://www.andymark.com/product-p/am-2204.htm
It fits in either a hydraulic or arbor press.
The 20 tooth steel gear I did for other teams look like this before I broach them:
http://www.andymark.com/Gear-p/am-0186.htm
You know that intelligence test where you put the round peg, in the round hole and the square peg, in the square hole?
In this case you push with about 1,100lbs of force until the round hole chisels out to a hexagon
Proving once and for all - brute force can solve problems.
Unread 05-02-2016, 12:16 PM
MVCI MVCI is offline
MVCI is an unknown quantity at this point
Is the output direct driving a wheel (ie output shaft going through a rigid frame)? Look into the possibility for relative motion between the output gear and its driving gear. This could be caused by loose transmission mounting or flexing of the plastic case. With extra load/impacts on the gears being part of this game and improper gear mesh (caused by relative motion between gears) I imagine this could easily happen.
Unread 05-02-2016, 12:18 PM
Reptilefox's Avatar
Reptilefox Reptilefox is offline
FRC #3230
Reptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of light
That exact thing happened to us (3230) at the Idaho Regional!
