Go to Post devote your life to FIRST. It will pay off. - suneel112 [more]
Unread 29-04-2016, 21:48
Thayer McCollum's Avatar
Thayer McCollum Thayer McCollum is offline
[Insert Name Here]
FRC #0159 (Alpine Robotics)
Rookie Year: 2015
Thayer McCollum will become famous soon enoughThayer McCollum will become famous soon enough
Re: pic: Another stripped VexPro gear
We had a VEX gearbox failure in the same type of gearbox. But it was the gears that failed, it was the casing. We took an especially rough underside impact and sheared the CIM right out of the black plastic. So... you know... we drove almost a whole match with a CIM hanging solely on its wires. (No way were we going to hit that E-Stop)
Unread 29-04-2016, 23:03
lethc's Avatar
lethc lethc is online now
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
The same thing happened to us at the OKC regional. We believe that a bind was caused due to a broken PTO chain and resulted in a stripped gear. We are using these gears on our Vexpro ballshifter gearboxes.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 29-04-2016, 23:30
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
As promised: http://www.chiefdelphi.com/media/photos/43781
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 02-05-2016, 10:27
LSanchez439's Avatar
LSanchez439 LSanchez439 is offline
AKA: Leonard Sanchez
FRC #3481 (Bronc Botz)
Team Role: Operator
Rookie Year: 2015
LSanchez439 is an unknown quantity at this point
Originally Posted by techhelpbb View Post
Hey FRCGuy are you sure you don't want my 2 lightly used 24 tooth Vex gears?
Cause...
It's probably too late for me to broach you steel gears.
I also don't have 24 tooth steel gears to start with and I doubt I can get them fast enough.
Going to put these on my list of 'coming soon'...
When you say 'broach' them some steel gears, what exactly are you referring to?
Unread 02-05-2016, 10:39
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You can Google "broach" to find some examples, but in this case, it is pushing a hex shaped cutting tool through a round hole to make a hex shaped hole.
Unread 02-05-2016, 11:23
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Buy a gear with a 1/2" round hole (also maybe a keyway) and push broach it 1/2" hexagonal.
The push broach looks like this (this one is from Dumont):
http://www.andymark.com/product-p/am-2204.htm
It fits in either a hydraulic or arbor press.
The 20 tooth steel gear I did for other teams look like this before I broach them:
http://www.andymark.com/Gear-p/am-0186.htm
You know that intelligence test where you put the round peg, in the round hole and the square peg, in the square hole?
In this case you push with about 1,100lbs of force until the round hole chisels out to a hexagon
Proving once and for all - brute force can solve problems.
Unread 02-05-2016, 12:16
MVCI MVCI is offline
MVCI is an unknown quantity at this point
Is the output direct driving a wheel (ie output shaft going through a rigid frame)? Look into the possibility for relative motion between the output gear and its driving gear. This could be caused by loose transmission mounting or flexing of the plastic case. With extra load/impacts on the gears being part of this game and improper gear mesh (caused by relative motion between gears) I imagine this could easily happen.
Unread 02-05-2016, 12:18
Reptilefox's Avatar
Reptilefox Reptilefox is offline
FRC #3230
Reptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of light
That exact thing happened to us (3230) at the Idaho Regional!
