Go to Post We have to have a water-based game discussion each year, because every time I try to start up a "jello-based game" thread no one takes me seriously... - dlavery [more]
Unread 30-04-2016, 21:52
Xifilzer's Avatar
Xifilzer Xifilzer is offline
Xifilzer is an unknown quantity at this point
Re: California Drive
Currently my team builds robots with a 6 wheel drivetrain (pneumatic or AM rubber wheels + omnis), and we just completed our 3rd season. This past season we built our own chassis (as opposed to a kitbot) and housed the wheels in 1" x 3" tubing on one side, and 1/8"plate on the other, and drove 8" pneumatic wheels using sprockets and chain. But, with our side plates taken off, our robot was stanced, and all the wheels were angled. We have accurately drill pressed all our holes, and house the shafts of the wheels through both faces of the tube. Is there a different means to go about constructing a West Coast Drive? How would you prevent your wheels from angling under load?
Thanks in advance,
Xifilzer
Unread 30-04-2016, 22:05
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Thanks in advance,
Xifilzer
Might be a dumb question, but are there bearings in BOTH faces of the box tubing? How much space is between the outside of the the box tubing and the wheel?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 30-04-2016, 23:07
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
How did you drill the holes? A drill press does not have the same ability to drill straight like a mill. I would suggest drilling the first wall, then use a transfer punch to get the second wall in the same location. For anything over 1/4" diameter, start with the hole in the first wall being the largest size transfer punch available, transfer it, then drill the larger hole.
Unread 01-05-2016, 17:25
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Originally Posted by Travis Covington View Post
The elegance and simplicity of the design, however, was something that had been done by team 60 for many years before the prototype 6WD drive train that was used at Cal Games in the Fall of 2003 and the collaboration between 254 and 60 that occured in 2004 and brought about the now well known 6WD West Coast Drive..
Do photos of the original still exist?
GitHub
Unread 01-05-2016, 18:16
Xifilzer's Avatar
Sorry a correction to my original post, we used pillow blocks mounted to the underside of 1x3 tubing instead of running the shaft through the tube.
http://www.mcmaster.com/#5913k61/=1285fnp
Looking from an aerial perspective, going from the outer side of the robot inward, this was our setup:
shaft collar, flange bearing in a 1/8"side plate, two 1/8" thrust washers, 8"pneumatic wheel bolted to a keyhub, a sprocket for 25 chain, two thrust washers, pillow block, shaft collar (for spacing), a sprocket for 35 chain, shaft collar.
This sums up to around 3.25" between the pillow block and sideplate, and 1.5" from the pillow block to the tip of the shaft on the inside. I'll try and take a picture tomorrow.
Thinking about it more, i think the pillow block may have been the source of our problems, since it allowed the shaft to pivot, instead of binding in place had we simply gone straight through the tube (with bearings XD).
