Go to Post Its not about Poof balls or green lights or getting up on the ramp at the end, this is about the learning experience and inspiration gained throughout the year. - Winged Wonder [more]
Unread 19-02-2016, 16:55
lnex1357's Avatar
lnex1357 lnex1357 is offline
Inspiration through Determination
AKA: Joshua Miller
FRC #2168 (Aluminum Falcons)
lnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud of
Send a message via AIM to lnex1357
pic: 2168 2016 Drive Train Top View
Unread 30-04-2016, 22:22
Xifilzer's Avatar
Xifilzer Xifilzer is offline
Xifilzer is an unknown quantity at this point
Re: pic: 2168 2016 Drive Train Top View
- My team built our first custom drive base this year (as opposed to a kitbot), and were considering doing it from here on out. We faced problems with our wheels angling, even though we had side plates, and our chain tension.
How did this drive train work for you guys in competition? Did you find problems with your wheels angling (Stance) causing your your chassis sag at all? And lastly what chain did you use and how'd that work out?
Thanks in advance,
Xifilzer
Unread 30-04-2016, 22:29
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
This is very nice. What size and type of wheels are those? They look like 4in colsons, but I feel like they are bigger than that. This is very similar to what my team wants to make as an off season rebuild.
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 30-04-2016, 23:52
ClockworkGold's Avatar
ClockworkGold ClockworkGold is offline
Wears Sparkly Gold Pants
AKA: Andrew F.
FRC #2169 (KING TeC)
ClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to behold
Which sprockets and gearboxes are you using?
2014: FRC 2169 Scouting and Spirit & FTC 7897 CAD
2015: FRC 2169 CAD, Strategy, Scouting & FTC Mentor 3385, 3387, 4509, 7899, 7900
Unread 02-05-2016, 17:30
lnex1357's Avatar
AKA: Joshua Miller
“My team built our first custom drive base this year (as opposed to a kitbot), and were considering doing it from here on out. We faced problems with our wheels angling, even though we had side plates, and our chain tension.
How did this drive train work for you guys in competition? Did you find problems with your wheels angling (Stance) causing your your chassis sag at all? And lastly what chain did you use and how'd that work out?”
So in general, this DT is nothing more than a standard WCD with 10 pneumatic wheels and a sheet metal belly pan. The only a-typical design feature is #35 chain and associated modifications to the WCP single speed transmission plate spacing. That being said some lessons learned post the 2016 competition season, that are applicable to your questions.
“Wheel sag” is an interesting one. Admittedly I’m curious as to the details on that one. What we did experience was deformation in our DT rails. This deformation was seen in upward bending in each of our bearing block pockets. A number of factors contributed to this which include:
  • Material Selection: We initially used the 0.1” wall Vex Pro tube stock and later at Championships switch to 0.125 wall. In most applications I would hold the opinion that the Vex Pro would suffice to do the job. But in this game it was not the ideal choice.
  • Our pocket “ears” the slots for the bearing block bolts to slide in and out of as the attached chain is tensioned were milled out too large due to manufacturing defects by our sponsor, i.e., we had to mill our slots to 3/8” wide to fix the errors which allowed the shock load on the bearing to be absorbed directly by the material above the bearing block and not shared by bearing block mounting bolt. Overall going forward we will use exact center to center spacing for our bearing blocks based on an exact chain length with pockets only large enough to bolt the blocks directly to the tube rail as opposed to making pockets to support sliding the bearing block for tensioning.
As I said earlier, we used #35 chain and sprockets. We never experienced any failures with this design decision. However, it did present challenges with respect to sprocket selection while trying to keep the chain above the belly pan and also required longer standoffs and mounting bolts to generate the required spacing in the WCP single speed transmissions we used.
“This is very nice. What size and type of wheels are those? They look like 4in colsons, but I feel like they are bigger than that. This is very similar to what my team wants to make as an off season rebuild.”
We used 6” pneumatic “zig zag” ties from WCP. These tires provided great traction on the terrain defenses, but experience a much higher ware rate than the diamond tread available from WCP, e.g., if we weren't taking risks we should have replaced ours after each event. This is because when inflated they crown at the center as opposed to the diamond tread which remains mostly flat. Additionally, because of this dynamic the zig zag tread introduces more scrub and creates challenges with respect to software controller gains that are constantly required to change as the wheels ware in order to maintain performance specifically this year in the instance where we were using the camera in concert with the DT for auto targeting. One other thing of note is the diamond tread tires are not as tall as the zig zag tires and thus the zig zag tires appeared to do a better job of absorbing the shock loads imparted by traveling over the defenses. In general, I personally do not recommend pneumatic tires unless the game requires them because of the wheel scrub you inevitably deal with. We use colsons religiously and only used the pneumatic wheels this year to absorb the shock load and create a high grip on some of the terrain defenses. One approach to this can be to do what teams like 1678 and 177 did which was to have their drop center wheels as colson wheels and the remainder pneumatic.
“Which sprockets and gearboxes are you using?”
We used 12T #35 sprockets from Vex Pro through the entire DT and 3 CIM single speed WCP WCD transmissions. Next year we will be building our own custom transmissions again for arrangements and ratio goals, but in general have no issues with the WCP transmissions. One thing we did learn however like many teams this year is to stay away from the 11T w/12T center distance pinions from Vex Pro.
Clarkson University 2010 / GENERAL DYNAMICS Engineer / EWCP / FIRST Volunteer
FRC Team 2168 - Aluminum Falcons, [2011-20xx]
FRC Team 229 - Division By Zero, [2004-2010]
"Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek."
Unread 04-05-2016, 17:36
Xifilzer's Avatar
@lnex1357
Thanks for the chain advice!
We used pillow blocks mounted to the bottom side of some 1 x 3 tubing in an effort to increase our ground clearance. The drive shafts ran through this on one side, and some 1/8" side plate on the other. The pillow blocks didnt work in our favour by acting as a pivot point for our shaft since our sideplates were held in by 8 rivets... In the future we are looking to put the shaft directly through both faces of the tube. In this manner the shaft will not be able to tilt even the slightest. Please feel free to give me any more advice you may have.
Sincerely,
Xifilzer
