Go to Post We did the best job we could out there, and unfortunatly we have human limits.. The refs don't catch every penalty, inspectors don't catch every issue, and this year the score keepers won't catch every single ball. - nobrakes8 [more]
View Poll Results: What did you use for vision tracking?
Grip on RoboRio - IP Camera 3 2.07%
Grip on RoboRio - USB Camera 9 6.21%
Grip on Laptop- IP Camera 19 13.10%
Grip on Laptop- USB Camera 6 4.14%
Grip on Raspberry Pi- IP Camera 5 3.45%
Grip on Raspberry Pi- USB Camera 13 8.97%
RoboRealm IP Camera 6 4.14%
RoboRealm USB Camera 7 4.83%
Other - Please Elaborate with a Response 77 53.10%
Voters: 145. You may not vote on this poll
Unread 01-05-2016, 13:04
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
What Did you use for Vision Tracking?
This year my team didn't have time to get into vision tracking. I've been trying to dive into it but before I get started I was wondering what the best option was. I've heard a lot of speculation about what is good and what is bad. I was wondering what people actually used at competition. I would love to hear feed back on what worked and what didn't work.
Unread 01-05-2016, 13:14
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
Re: What Did you use for Vision Tracking?
1261 used raspberry pi, with opencv. The vision code was written in python and used pyNetworkTables to communicate
Unread 01-05-2016, 13:54
Thanks for the in-site. How hard was it to write the code in opencv and use pyNetworkTables? Do you have any good resources or documentation that might help? Also how bad was the lag?
Unread 01-05-2016, 14:08
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
We used a very similar setup, except written in c++. We actually had virtually no lag on the raspberry pi side. The only portion where there was lag was actually the roborio processing the data from the network tables.
The setup was pretty simple to get up and running. We compiled opencv and networktables 3 on the pi, then wrote a simple c++ program to find and send the necessary data to align with the target back to roborio. I actually followed a video tutorial here to install cv on the raspberry pi. For network tables, I downloaded the code off of github and simply compiled it like a normal program and added it to my library path if i remember correctly.
Unread 01-05-2016, 14:14
granjef3's Avatar
granjef3 granjef3 is offline
Code Ninja
AKA: Matt
FRC #2383 (Ninjineers)
Rookie Year: 2016
granjef3 is an unknown quantity at this point
2383 used a Jetson TX1, with a kinect used as an IR camera. Vision code was written in OpenCV using C++ and communicated with the roboRIO over network tables.
During the offseason we will be exploring the android phone method that 254 used for reliability reasons; the Jetson+Kinect combo was expensive and finicky, compared to an android phone with an integrated battery.
2016 Galileo Division Semifinalists with 341 Miss Daisy, 3683 Team Dave, and 4525 Renaissance Robotics
Thanks to all of our past alliance members!
Unread 01-05-2016, 14:31
ajacob ajacob is offline
Lead Programmer
FRC #2791 (Shaker Robotics)
ajacob is an unknown quantity at this point
This year shaker robotics used the RRio with NIvision(java) to track the targets, we analyzed frames only when we needed them to prevent using too much of the rio's resources.
Unread 01-05-2016, 14:56
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
1771 originally used the Axis M1011 camera, and GRIP on the driver station. However we had a problem on the field, the network table data was not being sent back, and we couldn't figure it out.
We switched to using a PixyCam, and had much better results.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 01-05-2016, 15:02
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty
4901 used Grip on an a RPi v2 + a Pi Camera.
For more info on our implementation visit here https://github.com/GarnetSquardon490...ion-processing
John Fogarty
Unread 01-05-2016, 15:06
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
We used Java and OpenCV on an NVIDIA Jetson TK1, processing images from a Microsoft Lifecam HD3000.
Unread 01-05-2016, 15:26
David Lame David Lame is offline
FRC #0247
David Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the rough
Like most engineering decisions, there isn't a "good" and "bad", but there is often a tradeoff.
We used GRIP on a laptop with an axis camera? Why? Because our code for vision was 100% student built, and the student had never done computer vision before. GRIP on the laptop was the easiest to get going, and it only worked with an i.p. camera.
There are down sides to that. If you use opencv, you can write much more flexible code that can do more sophisticated processing, but it's harder to get going. On the other hand, by doing things the way we did, we had some latency and frame rate issues. We couldn't go beyond basic capture of the target, and we had to be cautious about the way we drove when under camera control.
Coprocessors, such as a Raspberry PI, TK1, or TX1, (I was sufficiently impressed with the NVIDIA products that I bought some of the company's stock), will allow you a lot more flexibility, but you have to learn to crawl before you can walk. Those products are harder to set up and have integration issues. It's nothing dramatic, but when you have to learn the computer vision algorithms, and the networking, and how to power up a coprocessor, and do it all at the same time, it gets difficult.
If you are trying to prepare for next year, or dare I say it for a career that involves computer vision, I would recommend grip on the laptop as a starting point, because you can experiment with it and see what happens without even hooking to the robot. After you have that down, port it to a PI or an NVIDIA product. The PI probably has the most documentation and example work, so that's probably a good choice, not to mention that the whole setup, including camera, is less than 100 bucks.
Once you get that going, the sky's the limit.
Unread 01-05-2016, 16:24
That is very true and I got grip working on a laptop so I'm trying to figure out where the next best place to go is. I don't know much about vision processing algorithms, python or openCV.
There is a good documentation for the raspberry pi which I have been working on when I can.
Thanks for the reply
Unread 01-05-2016, 16:34
FRC #1261
The code wasn't that hard for our developers, for openCV or pyNetworkTables. They looked at tutorials at pyImageSearch, it's a great resource. I think we were getting in the 20-30fps, but I would have to review our driver station videos. We would process on the Pi, calculate a few things such as, (x,y), area, height, (x,y) of center of image and such. This information would be sent via pyNetworkTables to the robot code. The robot code would use this information as input to elevation PID and Drivetrain PID.
The images were also sent via mjpg-streamer to the driverstation for drivers to see, but it's not really needed. We just liked seeing the shooter camera.
We'd be happy to help, just PM me.
Brian
Unread 01-05-2016, 16:41
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
We used a modified version of TowerTracker for autonomous alignment and a flashlight for teleop alignment.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 01-05-2016, 17:26
KH987's Avatar
KH987 KH987 is offline
AKA: Kevin Hjelstrom
FRC #0987 (High Rollers)
KH987 is an unknown quantity at this point
Team 987 used an onboard Jetson TK1 for our vision tracking. We programmed it with C++ code using openCV. The Jetson sends target information to the roborio with tcp packets. From there a compressed low frame rate stream was sent to the driver station for diagnostics. The low frame rate stream used very little bandwidth to ensure we stay well under the maximum (it used around 500 KB/s).
Unread 01-05-2016, 17:43
Simon_D Simon_D is offline
Rookie Year: 2016
Simon_D is an unknown quantity at this point
We ended up using the RoboRio with a USB Camera, but we attempt to uses opencv on Jetson, begalbone black and raspberry pi 3. We scraped the jetson after realizing how hard we were landing after hitting a defence. (But we had opencv working) then we had the begalbone scraped after the raspberry pi 3 was released. We got the pi to work after 16 hours of compiling opencv but we ran out if time.
