#76
Re: 2016 IRI Rule Change Suggestions
This might not be possible as FMS might need to be changed but....
Get rid of RP for breaching in quals and replace it with the 20 points you get in elims. Breaching should happen in every match, especially at IRI, and having it give an RP was an OP move by FIRST. Giving it the 20 point bonus still puts a emphasis on making sure the breach happpens. |
#77
Given that there were still missed crossings on Einstein, something should be done to fix that..
#78
Get rid of any and all tiebreakers. Replay every tie in elims.
#79
Eliminate the portcullis (already being done), drawbridge, and sally port. No more major visibility problems, no more problems with teams missing boulders they can't see. In return require all 5 defenses be knocked out for a breach, and as others have said give breaching a point value reward instead of ranking points.
No audience selection - just let the teams choose all of them. |
#80
Go back to explaining fouls.
#81
#82
Ties in eliminations are decided by another match not tiebreakers.
#83
Perhaps, but it doesn't really seem like there is that much space on the field to gain momentum, unlike 2014.
#84
![]() This. So much this. |
#85
In addition, remove the batter requirement for captures. I'm assuming tower strength will be raised for IRI and putting that many balls in the tower is an impressive effort in itself. Removing this requirement will remove the chances of a weaker 3rd robot losing the alliance 25pts by not being able to make it back to the batter on time, and opens up more strategic flexibility within the last 30s of the match. |
#86
For the breach, the importance is less, as one robot could theoretically achieve a breach alone, but if we are changing the capture, we might as well change the breach over to elims style too. The FMS might even let us do that already, though I am not sure where the play-style change made by the Scorekeeper, and if it necessitates actually running an elims bracket. |
#87
When I breach, your secret passage is no longer protected. I can get returning boulders with impunity, and cross back to the neutral zone without negotiating a defense.
This has the following advantages: - it encourages faster breaching. - it encourages higher scores - it gets rid of some penalties - it fits the theme This can be combined with many of the other permutations mentioned (forcing three crossings, crossing all five for a breach, doing away with ranking points, etc). You might also remove the one defender limit when the walls fall, if you want to force teams to be more strategic about it. Look at it like this - whatever you do by forcing additional crossings is still going to be easy for IRI teams to do in two minutes. Anything that's reasonable enough to be implemented will still happen every match, it will just take longer and we'll end up with less scoring. This wil make fast breaching more important while still keeping the focus for the audience on robots shooting balls. Last edited by Kris Verdeyen : 05-01-2016 at 10:03 PM. |
#88
I think a large amount of the issues I saw on that field were from uninforced rules, but adding another layer of protection is some positive step as opposed merely blaming refs. Also the definition of intent may be vauge, but I think we can all agree that giving up points or drawing fouls should count as intent. Maybe we can make that clearer. You can't accidentally tip a robot inches from the outer works outer works, they were already gone. You can't accidentally push a robot into your own secret passage from your courtyard in the last 25 seconds when they should be running away. I saw both of those things happen in our field, and it needs to end NOW. Last edited by Captain_Kirch : 05-02-2016 at 08:38 PM. Reason: Watching this match videos proved small but important details were misremembered. My apologies. |
#89
Any rule modification will be posted for teams before the Invitation Response deadline, so teams can determine if they want to play the modified game before they commit. |
#90
