Go to Post If you don't have a hairtie, use a ziptie instead. It works, it's cute, and way geeky. :p - Katie Reynolds [more]
Unread 01-05-2016, 22:15
bimbunky bimbunky is offline
App programming is dank.
Rookie Year: 2016
bimbunky is on a distinguished road
Average Team OPRs going in to Einstein
Some food for thought:
1: 2056 - 71.3922396241
2: 148 - 70.0640372296
3: 1678 - 61.6746235366
4: 1690 - 60.0464764582
5: 195 - 58.734126484
6: 330 - 57.3404216112
7: 987 - 56.802826136
8: 4678 - 56.7850558028
9: 2481 - 54.7325881845
10: 1986 - 51.9589946392
11: 2052 - 50.8941352961
12: 1501 - 49.789168129
13: 2122 - 49.1143966134
14: 217 - 48.4589076373
15: 3476 - 47.205222354
16: 379 - 46.7165911692
17: 3339 - 42.7481699705
18: 5050 - 41.7598876809
19: 120 - 40.5139406869
20: 41 - 40.177310552
21: 1065 - 39.646558455
22: 3015 - 38.9890248366
23: 1086 - 38.3333221328
24: 364 - 36.0320531408
25: 3538 - 35.8519716521
26: 1511 - 35.1514886306
27: 2990 - 34.4945152421
28: 694 - 33.6461602452
29: 188 - 33.1854360695
30: 1197 - 30.6396225515
31: 1405 - 28.8537837093
32: 4828 - 25.4473861927
Unread 01-05-2016, 22:34
TheMilkman01's Avatar
TheMilkman01 TheMilkman01 is offline
Cinematographic Extraordinaire
AKA: Luke Moss
FRC #2052 (KnightKrawler)
Team Role: Student
TheMilkman01 has much to be proud ofTheMilkman01 has much to be proud ofTheMilkman01 has much to be proud ofTheMilkman01 has much to be proud ofTheMilkman01 has much to be proud ofTheMilkman01 has much to be proud ofTheMilkman01 has much to be proud ofTheMilkman01 has much to be proud of
Re: Average Team OPRs going in to Einstein
Hey, thanks for doing this. It's really cool to contrast and compare each team and alliance on this list. Stats are always cool
"Today I will do what others won't, so tomorrow I can accomplish what others can't." –Jerry Rice
Unread 01-05-2016, 23:38
Rookie Year: 2016
I actually work with our team's scouting system so this is something that I really like to do
Unread 01-05-2016, 23:44
@bimbunky: Please define what you mean by "average" team OPR going in to Einstein.
i.e. what data are you including and how are you doing the averaging?
Unread 02-05-2016, 00:26
Rookie Year: 2016
The average of their OPRs of all of their respective regionals up until their subdivisions
Unread 02-05-2016, 01:56
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Just wanted to take this opportunity to point out how OPR is a pretty weak indicator of team strength. Our robot was projected to rank 53rd in curie before champs, but instead, we ranked 8th and captained our alliance to Einstein. We even took a game off of the world champions.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 02-05-2016, 21:30
Rookie Year: 2016
Indeed. But a team should have a generally strong OPR throughout their regionals also because their presence should allow them to score generally higher in their matches compared to other teams'. Even though OPR is not always accurate, across regionals there must be a chance of a good team being put on an alliance with bad robots, so their OPR is not high just because they have good robots on their team in each quals match.
Unread 02-05-2016, 22:07
christheman200's Avatar
christheman200 christheman200 is offline
Chris Lansdale, Programmer
AKA: Chris Lansdale
FRC #0854 (Iron Bears)
christheman200 is an unknown quantity at this point
On the contrary, a team may have had coms problems, etc. in one or more of their regionals, leading to a lower OPR. I wouldn't judge based off of averaged OPR for any other than the very top or bottom of the stats. That being said, I don't mean to bash the poster. I actually found this quite interesting.
Unread 03-05-2016, 19:06
Rookie Year: 2016
I'm glad you found it interesting! You're correct, OPR uses a linear regression (bunch of fancy stuff) that depends on the sum of all match scores for a team so in a way comes issues and such could potentially bring it down. Over several games, however, these are generally minor inconveniences although I agree OPR in the first place is an estimate and not always an agreeable number
Unread 03-05-2016, 19:07
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Yep. We were... 18th? in OPR coming into the competition and ended 40th and didn't even get picked. (Not to say that our crappy intake or our two matches where this whole concept of "team" was flown out the window wasnt to blame, but nonetheless it happenes here and it happens everywhere)
Unread 03-05-2016, 19:23
angelah angelah is offline
FRC #3547
angelah has a spectacular aura aboutangelah has a spectacular aura about
The fact that OPR doesn't correlate well with rankings doesn't necessarily make it useless. There is more than one logical conclusion to draw. I think the fact that it seems to correlate less this year than in previous years (from my random observations) is pretty interesting actually. I honestly wish I had the time and smarts to crunch the numbers more: OPR versus both rankings and alliance selection, for this year and the last two.
