Poor calling by refs Newton Subdivision SF2 M2
I'm not complaining, as there as obviously nothing that can be done about this at this point, but this was a very poor call by the refs.
https://www.youtube.com/watch?v=xUkv_Tj3SEo If you skip forward to 2:12 in the video, you can see 1477 from the blue alliance attempting to make its way back to the batter for the capture. However, on its way through the secret passage, the side panel came off of the defense in position 5 and prevented 1477 from crossing through the neutral zone. This slowed down the team very significantly, and prevented them from making it on the batter in the end. We tried talking to the refs about it, but their explanation is that "It could have been avoided." If we had the capture, it would have been an extra 30 points (25 for capture, 5 for challenge), and the blue alliance would have won the match 210 to 205. Either way, 5172 had a great time competing at this event. It's just too bad this is the way we had to go out. |
Re: Poor calling by refs Newton Subdivision SF2 M2
This should have been a field fault and had the match replayed.
I was not impressed with the referee quality at CMP this year. -Mike |
I agree even though I wasn't there on a couple matches that I watched quite a few matches to be able to tell the ref quality was not as it should of been and it could of been better but they should've checked the defense side shields to make sure they are secured at Michigan districts we used gafers tape to secure the end shield so technically it is a field fault/arena fault
If you read the section of the tournament rules that deals with field faults, the blue box underneath it reads:
Note that an ARENA FAULT that does not affect MATCH outcome in the judgement of the Head REFEREE does not lead to a MATCH replay. Examples include, but are not limited to: A. a piece of FIELD plastic falls into the FIELD in the last 5 seconds of a MATCH, far away from any human or ROBOT activity, and in such a way that it does not affect MATCH outcome B. delay in the playing of an ARENA sound C. mismatch between the timer on the Audience Screen and the FIELD Timer While it was in the last ~20 as opposed to 5 seconds, it would appear this piece of field plastic broke off and fell into the field and did not affect the match outcome. If you watch carefully 1477 gets stuck on boulders, not the actual field piece. So it was within the rights of the Head Referee to choose not to replay this match. |
I was pointing out the part about it not affecting the outcome of the match. The box also says that reasons not to replay a match are not limited to that list.
#7
It was not far away. 1477 touched it and knocked it off. However, it was not the divider that was holding them up, what was holding them up was a boulder, which you can see clearly in the image attached.
#8
I would argue that it was not plainly obvious that the plastic was a part of why they didn't make it to the batter. After initially knocking it off, they never contact the plastic again.
#10
Even if they had made it, you'd have lost points for them using the secret passage. If I remember right, this was immediately following the long discussion surrounding 254's potential second yellow card. With such a strict timeline, it's not surprising the refs would err on the side of "if any of those three things hadn't happened, they'd be on the batter and this would be a non-issue" rather than jumping to make a replay and push things further beyond the time limit. Given the conversations I heard over the weekend, the refs were very worried about making sure things were as fair as possible for all parties. Think about the thread title here. It'd be just as fair to say "Poor driving by 1477 on Newton Subdivision SF2 M2" but it shouldn't really be said, either. |
#11
2017: Divide and Conquer! |
#12
It's not the first time either unfortunately :/
#13
Referees are one of the most difficult roles to recruit for. It is a thankless position that causes stress and guilt and posts like this on CD.
If you're not happy with the quality of refereeing, then volunteer for the position yourself or help recruit other people who you believe will be quality refs. I know of at least two people who were irritated with the reffing situation this weekend, and both of them let me know that they absolutely will be refs in Indiana next year, to help us improve our local cache. Don't just complain on CD. Do something about it. |
#14
And it can go without saying that the team obviously would have driven over the rock wall and not through the secret passage if this incident had not occurred. |
#15
